Custom Car Ramps
Old May 21, 2008 | 03:43 AM
425skyline's Avatar
Custom Car Ramps
Even when my car wasn't slammed I had to use Rhino ramps to get the car up to proper height for the jack to reach the center jack points. I always use center jack points to reduce stress on the car while lifting it so it is crucial that I use those while working on the car. Even with stock height the front bumper would rub the ramps a bit.
Now I am less than 5 inches off the ground and can forget about using those same ramps. My jack is already a low profile, but just like all low profile jacks I have researched, only the nose has 3 inch height, then about 6 inches after the jack starts getting higher and higher, all the way up to a maximum height of a bit under 8 inches. Sure, I could have used the side points and etc, but like I said: to me that seems bad, especially with such a stiff suspension and lowered height.
I measured things out and in a nut shell the ramp angle had to be reduced in half, which would result in a ramp roughly twice as long as my Rhino ramps. The angle actually turns out to be about 12 degrees with an overall ramp length of 81 inches, which includes a 16 inch wheel stop (leveled part of the ramp for the wheels to rest on, instead of stopping on a slope. These ramps end up giving me a solid 10 inches of clearance, which is enough to crawl under and work if I need to do something quick like grease up my sway bushings. My muffler tips end up being 1 inch from the ground with the tilt and when the wheels are on the wheel stops, the ramp extends about half-way down my door (I have a coupe), so they aren't as monstrous as they sound. The different lengths you see in the picture (each level isn't the same length as the next and so on) are because I precisely measured the distance from the front of the bumper to the front of the tire and how to keep the bumper from rubbing at any time during the elevation.
I could draw up some blueprints/plans for anyone that feels the need. I basically had Lowe's (hardware store) cut up a bunch of 2" x 10" x 12' fir planks at exact calculated sizes. At home I stacked them appropriately and used liquid nails and 2.5" wood screws between every plank. They are solid as hell, but a little heavy. All I need to do now is screw some rope handles to the three sides for easy moving. So far they have cost me about $50 bucks in materials. Handles will be cheap too.
I didn't work on my car for nearly 3 weeks and it was torture. Tonight, after getting my car back from the body shop, I installed my test pipes. I'm back in business now.
Attached Thumbnails Custom Car Ramps-jack_ramps1.jpg   Custom Car Ramps-jack_ramps2.jpg   Custom Car Ramps-jack_ramps3.jpg   Custom Car Ramps-bling.jpg   Custom Car Ramps-bling2.jpg
Old May 21, 2008 | 01:48 PM
stillmatic's Avatar
Here's the DIY for the same setup:
http://www.mustangworld.com/ourpics/...amps/index.htm
Old May 21, 2008 | 04:54 PM
425skyline's Avatar
That's sweet. Pretty nice write up. I would do the alternating lengths for our cars though based on 24" inches from front of the tire to the front bumper and 5" from bumper to the ground. I drew out this whole thing about how the car actually goes up a certain amount and how far back the next level has to be in order to clear.
So I ended up with the following lengths in terms of traveling length of the tire per level of planks: 9", 19", 9", 19", 9", and 16" wheel rest = 81". It really works perfect and you always have a good inch or 2 clearance for every level of planks.
Old May 22, 2008 | 01:14 AM
425skyline's Avatar
Just bought some utility chest handles and some 3" lag screws to fit the 1/4" holes in the handles (they came with tiny screws). One handle on each side.
Old May 22, 2008 | 01:41 AM
jdmgee35's Avatar
awesome, that's a good idea.
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
Soumilg
Jul 23, 2015 09:26 AM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
