350Z H-tech springs (urgent)
May 22, 2008 | 01:30 AM
]Hey guys,
Pls advise.... much thanks
Can I use 350Z H-tech springs on my '04 G35 coupe?
How come so many people using 350Z H-tech instead G35 H-tech?
If I combine them with D-spec shocks, what will be approx. drop?
Can I ride without having adj. camber?
H-tech w/ D-spec shocks, is it a good match?
Pls advise
Thank you guys
Reply 0
May 22, 2008 | 02:00 AM
The search button is your friend.
Reply 0
May 22, 2008 | 02:13 AM
yes you can use them you will be fine. The reason is that the 350z ones are a little stiffer and lower it a tad bit more. i think the drop is .8 front and .5 rear
Reply 0
May 22, 2008 | 06:38 AM
Pls advise
Thank you guys
yes
350z h-techs are slightly lower and have better spring rate, stiffer, etc.
.5-.7" front, .5" rear if i remember approximately
yes, but you should get an alignment 2 wks afterwards anyway
yes
Reply 0
May 22, 2008 | 12:24 PM
Thanks guys for such great tips!
By the way, do I really need to purchase adj. camber to use 350Z H-tech springs? Some says, this is minimal drop and if I am in the budget, I don't have to use them. Few others informed me that I need to use them, what is my options? Honestly, if the issue is not that serious, I would like to avoid using adj camber. Pls advise.
Thanks in advance
Preston
Reply 0
May 22, 2008 | 08:57 PM
Thanks in advance
Preston
i'm getting my 350z h-techs installed this weekend without a camber kit, but i bought a rear spc kit and it's ready to go in two weeks when i get my alignment done.
so it's really on an individual basis depending on how much you drive, how much tire wear you personally find acceptable, etc.
if i can get my car into spec then im not gonna put on the camber kit, and since i wont be driving all that much after a month (not gonna be a DD anymore after i start school) i may not put it on at all even if my rears are a bit out of spec.
and as someone already said, search and you'll get all the info you need, this is a very frequently discussed topic. good luck.
Reply 0
May 28, 2008 | 02:08 AM
What is spc kit? Sorry, I am new to this
Reply 0
May 28, 2008 | 01:11 PM
Search "SPC"
Reply 0
May 28, 2008 | 01:44 PM
here's all you need to know:
https://g35driver.com/forums/lounge-off-topic/223904-you-know-you-re-noob.html
Reply 0
