Underbody component (pics)...
Old May 24, 2008 | 08:23 PM
TheG3nius's Avatar
I recently purchased my '04' coupe and have been going through the process of fixing many of the previous owner(s) neglect. And yes, you'd be surprised how rough a 4 year old luxury car can be. Anyways, does anyone know the name of this particular part of the car?
Searching didn't yield the exact name.
Old May 25, 2008 | 11:20 AM
SCoupe's Avatar
It's called a 'tunnel stay'. Acts as a brace.
Old May 25, 2008 | 12:20 PM
TheG3nius's Avatar
Thanks, is this an item that gets frequently damaged?
Old May 25, 2008 | 12:28 PM
RaginRaj11's Avatar
You dont really need that brace. I just got my exhaust installed and they just took it off.
Old May 25, 2008 | 01:16 PM
citymunky's Avatar
If the car is lowed.
Also it might be "need" to drive, but I'm sure it helps stop body flex
Old May 25, 2008 | 01:17 PM
Adon's Avatar
mine's all rusty from scraping, and I'm only lowered on tein s-techs.
it used to scrape even on stock height.
Old May 25, 2008 | 02:04 PM
TheG3nius's Avatar
My vehicle is at stock height. Eventually I plan to upgrade various underbody suspension. But is there an aftermarket replacement?
Old May 25, 2008 | 02:19 PM
Konsole's Avatar
apply some POR 15 to it if you want to stop the rust and protect it.
Old May 26, 2008 | 12:49 PM
SCoupe's Avatar
Yes .... there are aftermkt replacements. One very good one is by GT Spec, however, it extends lower than the stock brace and will scrape even more. And yeah, you DO need it. The tunnel is a weak point in terms of body flex which is the reason the brace is there @ all. If it's just scraped then no big deal but if is 'bent' outta shape then the stock or aftermkt unit is necessary. Can you tell the diff w/o it ? YEP .... over time you will be able to feel a difference.
Old May 26, 2008 | 12:54 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^+1
It's a structural piece, not a good idea to remove it.
Old May 26, 2008 | 03:30 PM
TheG3nius's Avatar
Is this the aftermarket replacement? The positioning doesn't look quite the same.
Old May 26, 2008 | 04:12 PM
cato's Avatar
SouthernComfort Moderator
Different part of car underbody. The GTSpec 4-point brace is not a replacement for that.
Old May 26, 2008 | 07:15 PM
TheG3nius's Avatar
What is the replacement?
Old May 26, 2008 | 09:01 PM
SCoupe's Avatar
That is the only known aftermkt replacement for the tunnel stay. While mounting points are different, end result is the same. It's reinforcing the structure from a wider stance. If you'll notice, the widest mounting points are inline with the widest points of the stock unit but it's obviously shifted more toward the center of the tunnel (front to back), hence the name. Again .... if your's is just scraped and the mounting points are in tact, then it's doing the intended job.
Old May 26, 2008 | 11:46 PM
TheG3nius's Avatar
If I get a chance to take some pictures of my undercarriage I will. My tunnel stay is crumpled, rusted and looks as though someone drove at high speeds over a consecutive series of speed **** (the more extreme speed bumps).
