Installed Eibach Sportline Springs, do I need a camber kit?
Old Jun 4, 2008 | 03:13 AM
loper411's Avatar
I have installed my eibach sportline springs, is it necessary to install a camber/alignment kit? Will I be alright without it?
Old Jun 4, 2008 | 11:03 AM
volcom_koda's Avatar
You know the drill.
Search.
to answer your question. yes. anytime a car is lowered it will most likely need a camber kit.
Old Jun 4, 2008 | 11:12 AM
Q45tech's Avatar
1" body lowering usually increases negative camber by 0.83 degrees. regardless of what brand of spring one uses.
Old Jun 4, 2008 | 12:01 PM
BlueDevilBAMF's Avatar
Sportline lowers >1" if I'm not mistaken. Yes, get a camber kit.
Old Jun 4, 2008 | 10:28 PM
XBrisk202's Avatar
yes, get a camber kit
if you want to be sure, get it aligned. they may be able to get the rears in spec but your fronts may not
Old Aug 4, 2008 | 11:39 PM
nalspeed's Avatar
how is your car do you have any pics how is ride quality compare to stock?? any camber issue i'm alos planning on getting eiabch sportline but a lot of people here says its too low compare to the prokit thanks
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
socalg35x
Aug 7, 2015 09:36 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
