My thoughts on Tein 350Z S techs before and after pics
Originally Posted by Gilley
I liked the drop I had with 350Z S-Techs. Even with my Greddy side skirts and Kuruma Z front, the car wasn't too low.
How is your OEM height 2 fingers?
My Stock 03 6mt had a 4 finger gap in the front, and 3.5 fingers in the rear.
I installed 350z H-techs and that brought me down to 2 in the front, and 2 in the back (more snug in rear).
I wish I it was a little bit lower
but as it is, I can just barely clear my driveway.
Usually take around a week (i have g stechs) and i'm going to do the spring mount mod to level it out. The rear on mine is also a little higher than the front.
Because 350Z S-techs give you a lower drop than G35 S-techs.
^Actually, I think their drop is pretty equal b/c the s-techs only will drop the 350z about 7" all around. I chose the Z s-techs because their spring rate are much closer to the stock sport suspension versus the G s-techs which actually decrease the rear spring rate substantially.
Rabbit - I don't have mine installed yet b/c I'm waiting for the threat of snow to pass. I'm curious about 2 things: 1) how would you compare the ride versus stock and 2) how did your front end alignment end up without a front camber kit?
^^^If you use the 350Z s-techs on a G the drop will be about .5" more than if installed on a Z.
If installing on a G35: G35 Tein S-tech have a slightly lower drop when compared to 350Z Tein S-tech. The difference is minimal but still there, the biggest difference is in the spring rates.
To answer your questions:
1. The ride on 350 S-techs is very similar to OEM sport springs, I did not notice too much difference. The front was a little stiffer and the rear was smother, but it took alot of paying attention to notice any difference.
2. My front end alignment was offl, I waited 2 weeks for the springs to settle and got an alignment. Then shortly after I got a front end camber kit since my camber was still off. You can get away with not doing a front camber kit, just know that your tires will wear out faster on the inside. I would suggest doing the front camber, rear camber, and springs all at the same time. The general rule of thumb is use a camber kit if you lower more than 1", and the 350Z S-Techs + springmount mod is more than 1" drop all around.
I no longer have this setup since then I have switched to Coil-overs.
Jiggerjuice
Aug 17, 2015 08:41 AM
TreeFiddy
Aug 10, 2015 06:50 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
