Camber kits needed with Tein S-Techs?
Old Jun 11, 2008 | 03:18 PM
G35Hokie's Avatar
Just got my G lowered with the Tein S-Techs, 1.0 in the front and .9 in the back I believe was the official measurements..
So what are my pros and cons for deciding on adding a camber kit, at least a rear. My question is along the lines of is it necessary in your opinions, does it just save tire wear, if so to what extent. Im new to suspension modifications, thanks.
Old Jun 11, 2008 | 04:46 PM
Nijo=Style's Avatar
https://g35driver.com/forums/brakes-suspension/226107-guys-z-s-techs-chime.html
this should have ur answers
Old Jun 11, 2008 | 05:36 PM
tragedycat's Avatar
Needed? no. Recommended? yes.
Pros
Save your tires
Cons
Camber kits cost $$$
Old Jun 11, 2008 | 06:11 PM
05GRide's Avatar
^+1
Nothing is absolutely necessary. You'll just be running neg camber which is out of specs. Most people agree that the rear camber kit is worth the money you'll save in tire wear since it's rather inexpensive. There are plenty of arguments about whether or not the front kit is needed/worth it. IMO (and I tend to "do everything right the first time") I'd get the front A arms. They cost twice as much but will allow for the adjustments you might want.
I'd for sure get the SPC rear kit. Lay off on the fronts if you don't have the $ and see how you like your tire wear.
Old Jun 11, 2008 | 06:37 PM
G35Hokie's Avatar
Who sells the rear camber kit for the best price and quality?
Do I need the toe arms as well?
Stillen sells the rear camber adjusters seperate for $319
When I order them are their multiple settings?..if so what are G35 spec settings to get the camber out of negative?
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
