stillen sways
Old Jun 12, 2008 | 12:27 PM
CreativeDesignZ's Avatar
stillen sways
I will be installing my stillen sways this afternoon. Im currently dropped on Greddy Type-S coil overs and would like a moderately agressive set up. I was thinking medium in the front and rear. Im not really sure as to what setting to adjust them to. I dont really track my car or anything but there are times when i drive a little bit spirited if you will. Im not looking to be snapping endlinks or even the bars for that matter so i do not want to go hard/hard. Any suggestions are welcome, thanks again guys!
Old Jun 12, 2008 | 12:30 PM
Klubbheads's Avatar
stay away from hard/hard setting, u will be fine.
Old Jun 12, 2008 | 12:32 PM
Jeff92se's Avatar
Red Card Crew
IMHO, I think it might depend on the spring rates of your coilovers. Even the softest settings are stiffer than stock so why not try soft/soft? It's easy to adjust anyway
Old Jun 12, 2008 | 12:36 PM
front spring rates are 10k and rears are 8k, i know its easy to adjust, i just want to see what others are running and make a decision based off of that so im not going in and out from under the car
Old Jun 12, 2008 | 01:40 PM
Ralph0064's Avatar
...whats up with the hard/hard settings?.....just wondering myself
Old Jun 12, 2008 | 01:49 PM
Klubbheads's Avatar
More load on the endlinks, which are designed to handle the stock sway bar, which is not solid and stiff as the aftermarket ones. It will cause the endlinks to fatigue and ultimately snapp in very harsh driving conditions like the track or hard canyon runs.
Old Jun 12, 2008 | 01:56 PM
Deepdiver's Avatar
OP, since you're not going to track. Hard/hard should be ok. I found that med/med is similar to the sport suspension sway bar (same diameter bar, same endlink hole position, similar body roll). I have spiritedly run hard/hard for about a year without issues.
Old Jun 12, 2008 | 01:59 PM
Jeff92se's Avatar
Red Card Crew
I do think most aftermarket med settings is quite stiffer than oem. Maybe the stillen units are diff
Old Jun 12, 2008 | 02:01 PM
Deepdiver's Avatar
thats what I'm thinking as well.
Old Jun 12, 2008 | 02:04 PM
Jeff92se's Avatar
Red Card Crew
Stillen:
Construction: 1 3/8-inch diameter (front) and 7/8-inch diameter (rear) tube bars
Bushings: None included (re-use OEM bushings or buy aftermarket ones)*
Stiffness settings for the front/rear sways: from 7% to 70% stiffer than stock
Old Jun 12, 2008 | 02:09 PM
so then would u suggest sticking with a med/med?
gary c's Avatar
Stillen Sway Settings....!
My Stillen sways have been set on MED/MED for two years now and that
works for me. One of my next mods will be to install ajustable endlinks due
to the OEM weakness. Adding beefer endlinks by itself will improve how well
the sways work.
Deepdiver's Avatar
(7% to 70%) however stillen never says which stock suspension (sport or non-sport).
Old Jun 12, 2008 | 02:10 PM
Deepdiver's Avatar
gary, what brand endlinks are you looking at and how much are they going for?
Old Jun 12, 2008 | 02:12 PM
Deepdiver's Avatar
I think you will be "happier" w/ hard-hard.
