Brembo DIY
Old Jun 16, 2008 | 12:05 PM
CreativeDesignZ's Avatar
Brembo DIY
I used the search, and all i could find was a DIY Video for doing brembo pads, i Need a DIY for Rotors and pads for a brembo equipped G. Thanks for all your help
Old Jun 16, 2008 | 12:39 PM
G35fromPA's Avatar
The rotors are probably the easiest part. Once you get the pads removed, just unbolt the caliper from the hub (two bolts), and make sure to hang/support the caliper (you can use a piece of wire or a bent coat hanger) to keep pressure off of the brake hose. Then, pull the rotor off and swap in the new one. If the rotor is stuck, take a rubber mallet and tap around the inside of it until it loosens. Before reinstalling, put some anti-seize lube on the face of the hub. That's pretty much it.
Old Jun 16, 2008 | 12:52 PM
FastDontLie's Avatar
...we dont need roads...
^ +1 they are real easy to do.
Old Jun 16, 2008 | 12:53 PM
what about the rears? i heard those were the tougher end to do, i couldnt find a write up for the rear. The fronts i think i have down it cant be THAT complicated, i mean i did my coil overs, sway bars, and other things so im not a complete mechanical failure lol
Old Jun 16, 2008 | 01:12 PM
Meatshackle's Avatar
Deep Sea Moderator
There's one on here for front and rear pads and rotors. I can't search for it now, sorry. I used it a few months ago.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
Jon81035
Sep 16, 2015 04:58 PM
