Stock 06 calipers vs g37's
Old Jun 24, 2008 | 04:19 PM
BrocksG's Avatar
Does anyone know what "pot" the calipers are for the 06 coupe and g37? I know some people are putting the g37 BBK on their 06 coupes / sedans but I'm wondering if anyone has tested the performance difference?
So I'm wondering (for example: ) if the 06 are 2pot / 4pot and if the g37 is 4pot / 6pot and if anyone knows a link to a site where they tested the g37 bbk on the 06 coupe compared to the OEM setup for the 06 coupe.
Thanks m8s
Old Jun 24, 2008 | 04:23 PM
Jeff92se's Avatar
Red Card Crew
the # of "pots" is not the deterimining factor for better/worse "performance". But one should clarify what "performance" is to you? 60-0? Brake fade resistance? Pedal feel? Affect on acceleration? ie.. G37 14" rotors are reported to be 26lbs. Rockalicious weight. Like having another set of wheels on the front.
Old Jun 24, 2008 | 04:42 PM
BrocksG's Avatar
60-0 and autox performance, such as heat resistance or consistancy.
And the # of pots usually result in clamping force which directly correlates into better 60-0 times no? I wasn't aware a 2pot/2pot setup could outperform a 12pot/12pot setup, please let me know if I'm wrong!
Thanks
Old Jun 24, 2008 | 04:46 PM
Alan's Avatar
a big part of brake performance is pad compound
Old Jun 24, 2008 | 04:47 PM
Jeff92se's Avatar
Red Card Crew
yes you are wrong. # of pots is usually an indicator of better feel. Clamping force is a function of total area of the pots.
ie.. if one pot's area = xxx area and if a 12 pot unit = xxx-2 area, then the clamping force of the 12 pot will be LESS.
Force applied to the rotor is also a function of the diameter of the rotor. Bigger rotor = caliper is further out = more torque arm advantage.
And good luck getting 60-0 times on various aftermarket bbk kits. 1/2 don't even address the oem bias much less if their kits actually make you stop sooner.
I have a post dedicated to this very subject. Look at my thread I've created in this brake/suspension section
Old Jun 24, 2008 | 05:16 PM
redlude97's Avatar
You can be very successful in autox with even the crappy OEM 03-05 brake calipers/rotors and good pads
MikeTanabe
Brakes
Aug 26, 2015 03:02 PM
Harman Singh
2nd Gen (V36) Sedan
Jul 30, 2015 03:39 PM
