steering quickness....
Old Jun 25, 2008 | 04:59 PM
Klubbheads's Avatar
Dofu I just read the description on tein tie rods and says that it will improve the steering angle. Doesn't that mean the u will be able to turn the wheels more? Maybe im understanding this wrong.....
TEIN Tie Rods and Tie Rod Ends are designed to replace weak OEM components. The TEIN units are not only stronger but are also capable of increased steering angle. By utilizing a larger diameter rod and stronger materials, TEIN was able to increase rod strength by 10~55% depending on application. The TEIN tie rod ends can be configured in two ways, OEM steering angle, or increased steering angle. Which allows for tighter turning radius, and deeper drift angles.
NOTE: TEIN Tie Rods and TEIN Tie Rod Ends are sold separately. V35 10.8 - M14 (Stock Tie Rod Diameter) 12.9-M14 (TEIN Tie Rod Diameter) 16% Strength Increase over Stock.
Old Jun 25, 2008 | 05:02 PM
ShanesG's Avatar
Sweet, Suscribed!
Old Jun 25, 2008 | 08:20 PM
Derzigster's Avatar
I think that the shorter wheelbase of the Z may attribute to better steering response. I have heard that the longer wheelbase of the G give it a better G force skid pad rating than the Z.
Old Jun 25, 2008 | 11:11 PM
Klubbheads's Avatar
I had that thought in my mind as well, that just the Z having shorter wheelbase gives better steering response. I am trying to look for the steering ratios for the G35 and there is nowhere i can find it.
Old Jun 28, 2008 | 12:37 AM
OCG35's Avatar
bump for updates...
Vlad, if this thread falls - you better look it up and post after you talk with Darin Wed...
Old Jun 28, 2008 | 04:40 AM
Klubbheads's Avatar
Originally Posted by OCG35
bump for updates...
I will. Can't wait! Hopefully he will have some detailed info about this.
Old Jul 2, 2008 | 04:19 PM
Klubbheads's Avatar
The answer is shorter wheelbase. Darren said that just shorer wheelbase will make a difference in steering input. So we can not do anything to offset it unless we shorten the wheelbase on our cars.
Old Jul 2, 2008 | 04:22 PM
ShanesG's Avatar
sucks for us....oh well
Old Jul 2, 2008 | 04:28 PM
Klubbheads's Avatar
+1, I still can smoke them on the track though. that is the most important thing.
Old Jul 2, 2008 | 05:38 PM
OCG35's Avatar
make it happen!!!
Old Jul 2, 2008 | 08:04 PM
Klubbheads's Avatar
^haha!
Old Jul 3, 2008 | 08:51 AM
ResIpsa's Avatar
Are you talking about turning radius or the actual feel of the steering wheel when you corner?
I ask this because a car that understeers feels heavier around corners. You would be amazed at how much you can transform the feel of your ride by increasing traction to the front wheels. Usually done by softer springs up front (or stiffer in the rear), bigger sway bar in the rear (smaller up front), or reducing shock damping up front (or increasing rear damping).
I was amazed at how much adjustability I gained after installing D-Specs. With a turn of the adjuster, I can make my G feel heavy as a boat or light as a feather.
Old Jul 3, 2008 | 11:17 AM
Klubbheads's Avatar
^no i was refering the steering quickness. Not the feel but how quick it responds to steering movements. Understeer/oversteer issue is resolved with sway bars only.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
G35xdriver04
Nov 7, 2015 08:31 PM
AuAltima3.5
Sep 13, 2015 11:48 AM
DG2Door
Sep 11, 2015 08:04 PM
Kicknshift
Sep 3, 2015 09:35 AM
