true coilovers or factory style coilover?
Old Jun 26, 2008 | 02:01 PM
envy-ths's Avatar
thinking about doing a drop "finally" and was looking for some input from some of the trusted members here, so here's my ? is it better to get a true coilover setup like stance use's or just go with the tein cs, the only reason im asking is because i would like to know if its gonna be safe to change up the suspension configuration? any and all help/ comments are welcome, so if you want to flame me for not using the search function then be my guest. p.s i do plan on getting the setup for the 350z so i can achive a lower drop without cutting my rear plastic things i forgot what they were called.
Old Jun 29, 2008 | 11:08 PM
meatbag's Avatar
The general consensus is to use the factory style setups as true coilovers put more stress on the rear mounting point then it was originally designed for. You will see people argue either way.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
TurTLe*
Sep 29, 2015 01:43 PM
alexbenz
Sep 26, 2015 11:30 AM
joeslates
Sep 11, 2015 11:19 PM
