EXPERTS PLEASE HELP::::: will edfc work with tokico d-specs??????? Need to know asap
Old Jun 29, 2008 | 12:25 AM
Da_ReD_G's Avatar
Lightbulb EXPERTS PLEASE HELP::::: will edfc work with tokico d-specs??????? Need to know asap
If anyone knows if this is possible to connect a edfc unit to tokico d-spec shocks??? If so is there anything to knowDOMO
Old Jun 29, 2008 | 01:56 AM
SxExCx's Avatar
Im gunna say NO
Old Jun 29, 2008 | 08:10 AM
Gilley's Avatar
I have never read or heard of it being done.
Old Jun 29, 2008 | 08:37 AM
Nismo G's Avatar
Me neither...im going to say it wont work. The only way i can see it working is if the damper adjuster hex screws are the same.
-Sean
Old Jun 29, 2008 | 01:08 PM
Da_ReD_G's Avatar
damn that sucks monkey *****. so where can i get this adjustment extension at. DAMN IT I KNEW I SHOULD I JUST GOT TEIN CS
Old Jan 6, 2011 | 11:39 AM
famiglia's Avatar
Has anyone actually confirmed that the Tein EDFC won't work on the D-Specs, or are just assumptions being made?
I know this is an old post, but I thought I would just try my luck.
Old Jan 6, 2011 | 11:45 AM
LordFappington's Avatar
Im sure if you really wanted to you can make it work.. Not sure how you are going to do the rears tho.
Old Jan 6, 2011 | 01:25 PM
famiglia's Avatar
A little bit more research revealed this:
p.s. i spoke with tokico friday and they said that the tein edfc fits on the tokico d spec shock and does work but there trying to reprogram the unit to turn more rotations. they said that it only turns about 4.5 rotations when the tokicos need 7.5 turns.there experimenting with it to see if it would be worth producing. im trying to confirm that 4.5 turns is right because then it would work just with limited adjustablity, which i could live with.
Source: http://my350z.com/forum/brakes-and-s...er-issues.html
Looks promising, if I am okay with staying in a limited range of the adjustment. Plus, even if I get tired of the limited range, and my D-Specs will get old and need to be replaced at some point. I'll just get me a new Tein coilover set. I'll have the Tein EDFC ready to go.
Old Jan 8, 2011 | 01:11 PM
DivZero's Avatar
Pretty ignorant to say it won't work because you have never heard of it being done before. Did you know that steel boats won't float in water?
If the adjustment mechanisms are in similar spots then EDFC should be at a MINIMUM adaptable to the d-specs. As mentioned in post #8, the rotation might be off, but it would still allow adjustability. EDFC is just a twisting motor and motor control unit. It will attempt to twist whatever it is attached to.
Old Oct 5, 2014 | 11:47 AM
famiglia's Avatar
Just as an update to close the issue. I got the Tein EDFC and tried to put them on my Tokicos. In summary I ended up not doing it because it would have required custom machining a part or finding some perfect part that does not seem to exist. In the end, I just swapped my Tokicos for Tein Street Flex.
Here are some notes, detailing out my experience.
- When you buy the G35 recommended Tein EDFC it comes with the 12120 (12mm) motor kit, but Tokico needs the 10mm. (I might have this mixed up, be sure to research).
- The male hex key coming out of the Tein motor is the same size as the Tokico female hex key seat (I think 5mm), BUT it is does not extend far enough out of the motor to reach the Tokico seat. This is the custom piece that I could not find or make. It needs like a hex key extension of sorts.
- Besides the fact that the EDFC would not allow me to control the full Tokico range, I was also concerned that the EDFC reset procedure would over crank the Tokico and break it.
If anyone has clarifying questions, just let me know.
I do have to say that having the EDFC running with my new Tein Street Flex is awesome, but I actually think I liked the feel of the Tokico more than the Tein SF. Maybe I just need get use to it.
arora_g35
Apr 16, 2026 02:52 PM
Th611
Oct 27, 2015 03:48 PM
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
attarday
Jul 15, 2015 04:03 PM
