Brake Bias Testing & Adjusting
Old Jul 7, 2008 | 08:03 PM
G35fromPA's Avatar
Originally Posted by helldorado
EBFD is part of the ABS module and really just an enhancement of ABS functionality. It ties its best to vary brake force at all four wheels to optimize brake torque without lockup.
If I have a chance later, I'll have to see if I can dig it up from the FSM.
IIRC from the FSM, EBFD really only kicks in if it detects slippage.
Old Jul 7, 2008 | 08:45 PM
Jeff92se's Avatar
Red Card Crew
Which is why I stated it was a crude estimate to get you in the ballpark
If you want it as fine as you imply, you won't be able to do the calculations without some serious equipment and a test facility. At some point, you will have to make concessions in order to complete you calculations.
Old Jul 7, 2008 | 08:59 PM
redlude97's Avatar
but whats the confidence intervals on your calculations at that point? +/-5%? 10%? 15%?
Old Jul 7, 2008 | 10:10 PM
bigc's Avatar
Wings Nation
^ this is turning into a stats class
Old Jul 7, 2008 | 10:31 PM
Jeff92se's Avatar
Red Card Crew
Depends I guess. What are the various BBK maker's stats? -/+ 5% might be pretty good, if their products affect bias in % of 10-25%?
Like I said, relative to what these bbk makers put out, it's probably tons better. Relative to what the oems use for their own calculations, it's probably error prone. I was just saying we aren't comparing the oem systems. If your calculations on the oem systems come out to something close to what they publish, then your calculations are probably good when you input the aftermarket bbk specs.
Do your calculations have to account for drilled/slotted rotors vs blanks?
Hey you're the one doing the calculations. I was just trying to make it easier/faster considering the terms of the discussion you wanted to put them into. Research on my friend.
Old Jul 8, 2008 | 03:11 PM
Q45tech's Avatar
The problem is you don't have graphs for pad friction vs temperature and graphs for friction vs application speed.
Obviously all these will change with wear so you need multiple graphs based on pad thichness
Old Jul 9, 2008 | 10:37 AM
ResIpsa's Avatar
I found this at http://autospeed.com/cms/A_110601/article.html
Put simply, what you need is for front brakes to lock the front wheels slightly before the rear wheels lock. (No, we're not talking cars with ABS here!) This means that the car remains in a straight line, steered and stabilized by the rear wheels. With the rears locked up, the back wheels steer the car and the steering wheel is virtually useless.
There are several ways of testing brake bias. You can find a brake dyno, or alternatively grab a friend and some chalk or duct tape and then find a vacant road to do some testing. The marking materials are used on the tires so that your friend can more readily tell which wheels - the front or the back - stop turning first.
If there is a bias problem (and of course the brakes are in good condition, with no seized pistons or anything like that - see the breakout box at the end of this story) it is then up to you to sort it out or take it to an expert. However be prepared for no help from most brake centers, as changing values in a brake proportioning valve is not something that they normally do - or, in my experience, even want to do!
Old Jul 9, 2008 | 10:39 AM
ResIpsa's Avatar
Also check out http://dsr.racer.net/brake_bias.htm
Old Jul 9, 2008 | 12:00 PM
Jeff92se's Avatar
Red Card Crew
I don't think our oem brake porportioning valves are adjustable anyway
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
linedr89
Aug 17, 2015 05:11 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
