S TECH Questions
Old Jul 7, 2008 | 12:29 AM
HoCkeYBrAhCA/MN's Avatar
S TECH Questions
i have 19's
8.5 in the front and 10 in the back. with the s techs installed will there be any rubbing issues? thanks
nick
Old Jul 7, 2008 | 09:54 AM
anyone
Old Jul 7, 2008 | 01:22 PM
str8dum1's Avatar
anything wider then a 275 will rub with lower than a 22 offset.
Old Jul 7, 2008 | 02:24 PM
mine are 275 i think. i know there not 275 in the front forsure.
thanks man. also it snows here. and the g is already pretty low...will i have any probs? i dont have a lip.
Old Jul 8, 2008 | 07:14 PM
do i need to buy a camber kit when i install my spring?
Old Jul 9, 2008 | 08:52 PM
EL-EE-ES's Avatar
a rear camber kit would be smart
Old Jul 10, 2008 | 05:36 PM
05GRide's Avatar
Hockey, rubbing will depend on your offsets. As stated above, running lower than a 22 offset with a 285 tire, you will need to have your fenders rolled. I have +23 offset with 285 BFG KDWs in the back and I had to roll my fenders 100% when I dropped my car.
As for camber, people argue on here that the rear is always a must since it's so cheap. With S techs your front will be out of spec, which would require a front camber kit (upper A arms) to bring back into spec. There are arguments both ways on whether or not the front kit is worth it. IMO, I do everything "right" the first time, and I got the front A arms. I'm also dropped more than S techs, but if you don't mind going through front tires a bit faster, then it's not needed.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
youngdip631
Lighting
Aug 27, 2015 03:49 PM
zcherub
Aug 27, 2015 09:47 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
