Front Camber A Arms...Ichiba or Top Speed?
Old Jul 14, 2008 | 07:04 PM
mpapers's Avatar
Hey guys,
Im running neg 2 camber and need to fix it as my tires are now being destroyed. Im on a budget and am not buying spc arms at $400. I have found both the ichiba and top speeds for a reasonable $250 so im deciding between both. Anyone know which is better? I know ichiba is china and they havnt been around to long. Im leaning towards the top speed as they are based in Dalas and that makes me feel better but i really dont know......
Old Jul 14, 2008 | 07:12 PM
redlude97's Avatar
Neither arm is made really for correcting negative camber,and both only provide ~1/2 degree of positive adjustment. They are made to add more negative camber for better handling.
Old Jul 14, 2008 | 08:27 PM
godmans's Avatar
(To my knowledge)
They are parts of almost identical quality.. but if you wanna do it right, try to see if you can find some used SPC A-arms here or on MY350z.com
Good luck
Old Jul 14, 2008 | 08:58 PM
mpapers's Avatar
I called top speed about that, as I thought the same but the +.25 is what you can move it two from the stock camber of -1.0 meaning that there is a total of +1.25 you can adjust it to. So for my situation of -2.0 I could max it out at -.75.
Old Jul 15, 2008 | 11:12 AM
Konsole's Avatar
I have my 2 degree hub spacers from my SPC A-Arm kit that I am not using... would that help you at all? My SPC A-Arms had enough adjustability that I did't need the spacers.
Old Jul 15, 2008 | 11:42 AM
mpapers's Avatar
I dont know, How does that work? Will it fit on the stock arms? Does it move it a full 2 degrees? I dont want to be at 0. The max i want to be is -.75 Please let me know. Thanks
Old Jul 15, 2008 | 01:10 PM
Konsole's Avatar
The spacers give you 2 degrees positive camber. You could then adjust whatever A-Arms you have to get your -.75. The spacers just allow you more positive camber adjustment (so if your A-Arms wont adjust far enough, these will do it)
They will fit any Z/G, they dont have anything to do with the A-Arm. In the pics below.. its the two brackets, one round and one just slight bent and the ABS sensor bracket.
You could use the 2 degree spacers with stock arms, it would just give you exactly 2 degrees positive camber from stock.
They are installed behind your brake rotors and on the brake caliper mount. Fairly simple install, just be careful not to bend the abs sensor mount bracket (the sensor needs to be within a certain distance of the rotor)
Old Aug 14, 2008 | 01:26 AM
mpapers's Avatar
I just installed the pro-1 a arms and not impressed. they max out at a positive 1. So im still at negative 1. You still not using those spacers
Old Aug 14, 2008 | 12:43 PM
Konsole's Avatar
Still have them. Not sure what they are worth, but I can give you a good price since I don't need them.
Ill figure out a price.
Old Aug 14, 2008 | 01:09 PM
redlude97's Avatar
that doesn't make any sense, how can they have more adjustment when the camber is more negative, than when its positive? There is only so much adjustment, and the actual camber numbers are dependant on drop height
Old Aug 14, 2008 | 01:11 PM
redlude97's Avatar
why do you want to run even less negative camber? Handling performance will suffer greatly
Old Aug 15, 2008 | 05:36 PM
05GRide's Avatar
+1 Red... not to mention that our cars aren't all set OEM at -1.0 camber... You will get 0.5 degrees of positive camber correction over whatever you're currently running with those arms, period. That would mean if you are at -2.0, you'll be able to get right on the outside edge of the stock specs.
I have the SPL A arms and they don't even offer 1.25 degrees of positive camber correction and they are considered one of the nicest sets of A arms for our cars...
Old Aug 15, 2008 | 06:56 PM
mpapers's Avatar
-2.0 camber is entirely to much neg camber. There comes a point when you have to much neg. camber and handling is reduced. I just got a alignment today and g35ride your right i only went from -2.0 to -1.5. However even with this slight improvement my handling has been increased not decreased leading me to believe that -2.0 is past the point of helping and actually hurting but thats beside the point. The main reason i want to decrease it is because my brand new tires with only 3k are getting shredded on the inside. There is already a inner front tire issue with g35s and when you bring camber to -2.0 it increases the feathering 10x. I dont feel like buying new tires every 6k. I dont know about you.
Old Aug 15, 2008 | 06:57 PM
mpapers's Avatar
Konsole, you figure out a price yet?
Old Aug 15, 2008 | 07:29 PM
redlude97's Avatar
It sounded from your post like you wanted to run -.75 camber up front, if I interpreted what you meant incorrectly, then I apologize. IMO anywhere from -1.2 to -1.7 is a good amount of camber for a balance or handling and tire wear
