Question about stock front sway bar diameter (05 coupe sports suspension)
Does anyone know what the diameter of the stock front and rear sway bars (OEM 2005 G35 6MT Coupe - Sports suspension) are? I need new sway bar bushings, basically I wanted to know if the Prothane Motion Control 14-1115 would work for the fronts and 14-1116 for the rears.
I tried searching but all the information is for aftermarket.
Thx!
Thx!
Originally Posted by teampump88
anyone? thanks!
Group A
03-04 350Z all trim levels (car's without the revised suspension ONLY)
03-06 G35 coupe (all USDM production with oem 17 and 18" wheels)
03-04 G35 sedan (sport and non sport suspension's
All group A car's have the following oem sway bar specs
34mm front 21mm rear
hollow wall construction 5mm in thickness (courtesy of tomsn16)
Torsional rigidity Front: 1130lbs Rear:385 (courtesy BJ EVO350)
Group B
04.5-06 350Z all trim levels (car's with the revised suspension)
05-06 G35 coupe (all USDM production with oem 19" wheels)
04-06 G35 sedan (sport and non sport suspensions)
hollow wall construction 7mm front (courtesty tomsn16) 5mm rear
net change in front bar strength from 2mm increase in wall thickness
+17% (courtesty of tomsn16)
rezendvous420
May 31, 2020 01:26 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
kinetek
Aug 3, 2015 04:25 PM
vstypicals
Jul 20, 2015 10:55 PM
