? For those lowered with aftermarket sways and stock endlinks
Old Jul 22, 2008 | 04:50 AM
my05g35sedan's Avatar
For those who are lowered at least 1" and are running aftermarket sway bars with stock endlinks:
1. Does the preload that you have with the stock endlinks pushing on the sway bar ends effect handling adversly?
2. For those that have switched to adjustable end links that you can make shorter than stock is there a noticable difference?
ONLY THOSE WITH EXPERIENCE PLEASE
Old Jul 22, 2008 | 05:27 PM
05GRide's Avatar
I can only kind of speak to #2. I just put the Powergrids on when I got my sway bar. I actually had to lengthen the rear ones to remove the preload, just some clarity there.
From what I've seen, there are quite a few people that complain of creaking and noises going over bumps. I believe some of it can be attributed to the amount of preload on the aftermarket sways/stress on the endlinks. I have no clunking.
I can tell you that my car is very neutral going in and our of turns. Plus I have no second thoughts about running my sway bar at full/full!
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
neight
Steering & Suspension
Aug 7, 2015 02:48 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
