Performed the OEM non-brembo brake upgrade to 06 Z brakes
Old Jan 26, 2010 | 12:06 AM
  #46
Swivel's Avatar
Moderator
Cool. Done yet?
Now?
How 'bout now??
Old Jan 26, 2010 | 01:01 AM
  #47
Hammerhead i-Eagle Thrust's Avatar
lol
according to ups they are still in VA
Old Jan 26, 2010 | 07:10 PM
  #48
Jeff92se's Avatar
Red Card Crew
Originally Posted by SwivelHips
Same question. Any balance or proportioning issues? Can't imagine there would be, but I also doubt many people have done just the fronts. If so, post up!
I just wonder if it's worth doing the rears at all, since the size difference is small, same 1-piston setup, and most of the braking takes place up front.
You want to do both. Most of the braking IS up front but it's the bias ratio you want to balance. Too much front makes it easier to lock them up and nets you more front end dive.
I've experienced too much front bias when I put 13" rotors and Z32 calipers on my maxima. It would lock and dive pretty good. When I upgraded my rears (happens to be a simple bracket and larger rotor upgrade) the braking was MUCH flatter and it locked up much less.
Old Jan 26, 2010 | 07:12 PM
  #49
OCG35's Avatar
^^^ didn't your Maxima have ABS?
Old Jan 26, 2010 | 07:20 PM
  #50
Jeff92se's Avatar
Red Card Crew
The POINT being BIAS is important to maintain.
ABS was optional on SE models.
Old Jan 26, 2010 | 07:22 PM
  #51
what about bbks though...the vast majority dont even bother with the rears
Old Jan 26, 2010 | 07:29 PM
  #52
Jeff92se's Avatar
Red Card Crew
This thread isn't really intented for brake bias. I'll state that Iv'e discussed this issue at depth already
https://g35driver.com/forums/brakes-...bout-bbks.html
Old Mar 9, 2010 | 11:06 PM
  #53
Skyfox16's Avatar
I replaced my rotors and pads all around about a year and 20K miles ago and im starting to notice the vibration and signs of needing new front brakes. I have EBC slotted rotors with EBC red stuff pads right now..... im looking to do the upgrade to the 06 calipers and rotors and was just wondering if i upgrade the front rotors/calipers, do i Have to upgrade the Rear rotors/calipers?? or am i able to run the 06 13" rotors in the front and keep the stock 05X 11" rotors in the back??
thanks!!
Old Mar 9, 2010 | 11:22 PM
  #54
thanks!!
they are 12.58, not 13"
im gonna run them with stock rear brakes...there are mixed opinions about it if u read the thread. when the rears need to be replaced im gonna upgrade them too
anyone have any suggestions for good blank rotors. I was thinking ebc or centric premium but i was just wondering if anyone had any other ideas or good sites to buy brakes
Old May 14, 2010 | 04:17 PM
  #55
V's G's Avatar
subscribed so I can do this soon.
Any new comments on the performance? From your experience, how long do these pads last compared to the former setup?
Old May 14, 2010 | 04:20 PM
  #56
Jeff92se's Avatar
Red Card Crew
performance is what the 05+ non awd G35s would do. Which is great. Pads will last longer and rotors won't be so prone to warp. Less dust too.
Old May 14, 2010 | 04:33 PM
  #57
i swapped just the fronts..hard to tell much of a difference but it seems like the car takes less effort to stop if that makes any sense...still seems to be some brake dust, probably not as much but I am using ebc green stuff which probably arent the best thing for dust
Old May 14, 2010 | 05:00 PM
  #58
V's G's Avatar
if i can get rid of the stupid brake squeak and reduce the brake dust, i'll be ecstatic.
jsimonk
Dec 22, 2023 03:49 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
mushu
Jul 15, 2015 03:55 PM
