Front suspension noise after adding new springs
Old Jul 27, 2008 | 01:25 PM
DRIZCOL's Avatar
I have been plagued with a noisy front suspension on my 03 coupe for the last 6 months. When driving at slow speeds over bumps on the road there was a horrible popping rattling sound. I believe it stared because the roads here are so bad, tons of potholes everywhere. I took the car into the dealer and they told me it was my compression rods. They quoted me $900 to replace them. I decided to buy the parts for $295 shipped and replace them myself. It took 4 days to get the old compression rods off to replace the new ones. It was well worth the effort at the time because it solved my rattling problem.
About 2 weeks later I decided that I needed to buy 350z Tein H-Tech springs to lower the car. Now that I replaced the springs the same danm poping rattling sound is back. Son of a bitch! After doing some reading on the forums and finding out a lot of people had a similar problem because of bad end links. After reading that I remembered that while taking off the driverside endlink to replace the springs I noticed that the end link bolt that connects to the lower arm had spun when I tried to remove it. So I ordered SPL end links and installed them yesterday. I followed all the directions that SPL provided to set them up correctly.
I took the car for a ride after I was finished only to find that the sound is still there.
I dont know what to do next. Is it possiable that the driverside compression rod is already bad? please help!
Old Jul 28, 2008 | 09:39 PM
DRIZCOL's Avatar
bump
Old Jul 28, 2008 | 10:52 PM
CreativeDesignZ's Avatar
do you run sway bars?
Old Jul 31, 2008 | 01:45 PM
10nara's Avatar
Might want to check your shocks. Mine made that noise when my shock went bad. Noise free after some d-specs.
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
jimNC
Jul 25, 2015 05:47 AM
