how do I adjust the rear d-specs ?
Old Aug 1, 2008 | 11:35 PM
GeeCoupe's Avatar
I adjusted the front two to the suggested starting point (5 turns counter clockwise) now how do I get to adjusting the back two?
Old Aug 2, 2008 | 01:42 AM
EL-EE-ES's Avatar
you have to pull them off. they adjust at the same location as the fronts, on top. you can get extensions so that you can adjust them from the inside of the car
Old Aug 2, 2008 | 01:46 AM
EL-EE-ES's Avatar
these are the extensions
https://g35driver.com/forums/brakes-...35-coupes.html
Old Aug 2, 2008 | 11:46 AM
kenchan's Avatar
raise one side of the rear, remove the rear wheel.
remove the two nuts at the top mounts (rear shocks) and pull the
mounts down and hold.
remove the protective cap, fit the 3mm d-spec adjustment tool, turn,
put cap back on, let the shock extend by itself into place, and tighten
the nuts snug, but not super tight.
do the other side.
im at 1.5 turns from full stiff front, 2.5 on the rear. feels good.
Old Aug 2, 2008 | 11:47 AM
GeeCoupe's Avatar
Thanx, that's exactly what I needed and they are actually pretty cheap!
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
