are our factory camber adjustable?
i heard both sides.. that it's not and that it is... so which is it?
i am dropped on 350z tein h-techs.. do i need rear camber kit?
Adjustable in the same way wear and tear or impact changes the parameters!
You can shim or bend the subframe and mounting points to the corrrect position.
Strut tower braces help dampen the natual tendency of shock towers to bend inward after years and years from constant impact pressures.
1/16" can cause a significant camber error.
Easier to acquire adjustable components so that the parameters can be adusted to perfect every 90-180 days.
i got my alignment done today..
how's the specs look?
https://g35driver.com/forums/brakes-...ent-specs.html
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
