How's my alignment specs?
Old Aug 9, 2008 | 08:47 PM
akachi's Avatar
I am dropped on 350z Tein H-Techs. I got the SPC rear camber kit but not the front. They told me they can't really adjust the front w/o the front camber kit.
Will I have big tire wear if I leave the front as it is? Also, is my rear in good spec?
Old Aug 9, 2008 | 11:09 PM
akachi's Avatar
anyone?????
Old Aug 9, 2008 | 11:55 PM
Glex25's Avatar
Administrator
I usually run 1.8 deg camber in the front and 1.6 rear camber. I got the SPC front camber kit and rear but the camber settings I have is of my choosing.
Left front is not so bad you just barely out of the accepted range for front camber, right front is a different story.
Old Aug 10, 2008 | 12:00 AM
akachi's Avatar
i'm sure if i sit in my car, the front left camber will be more negative which will closely match the right side..
Old Aug 10, 2008 | 11:07 AM
jlin615's Avatar
Do you have your rear spec before the camber kit?
Old Aug 10, 2008 | 02:17 PM
mIKE's Avatar
Front is a bit off, but the rear is almost spot on
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
