need help what type 350z springs
Old Aug 13, 2008 | 04:15 PM
skull_leader's Avatar
g sedans, need help what type 350z springs
just purchased a set of 350z springs from a 350z roadster. i did a searched and the springs don't match up... help please... revised or unrevised, 350z?
Attached Thumbnails need help what type 350z springs-springs.jpg   need help what type 350z springs-springs-2.jpg   need help what type 350z springs-springs-3.jpg
Old Aug 13, 2008 | 04:23 PM
Texasscout's Avatar
They look just like my Unrevised springs, sam style and markings.
Old Aug 13, 2008 | 04:32 PM
what color are the rears? the springs i have a blueish/white single dot. i dont know if you can tell in the pics. kind of baby blue. and i assume the 3 red dots are the fronts?
thanks for the fast response... do you have pics of your ride... and also how are the handling and ride quality.
Old Aug 14, 2008 | 12:32 AM
GF-4D-G35's Avatar
I have no idea which springs those are but I can tell you that the ride with the revised springs is great. I also have the z shocks so that might also have an impact on the ride. If you have the normal shocks and put those on you will need new shocks soon, the different spring rate will wear the shocks out very quickly. With unrevised you should be fine if you have the sport shocks. With revised your rears might go since the spring rate would not match.
Old Aug 14, 2008 | 01:10 AM
Tunerz_Store's Avatar
A 04.5+ Z REAR spring will have 2 red dot's and 1 pale purple dot. A 03/04 REAR Z spring will have either 2 red dot's only or 2 red dot's and 1 white dot.
Old Aug 14, 2008 | 11:10 AM
confused
ok... now im confused,
texas has confirmed that i have unrevised 305z springs...
but hybrid states those dot dont match up with my springs...
one set has 3 redt dots (2 on one coil, 1 red dot on another coil.
the other set set has 1 white(pale blue?) on a coil...
please clarify which is the front and back...,
and if they are revised or unrevised...
or even are they from a z or g...
thanks guys for help in advance..
Old Aug 14, 2008 | 12:40 PM
more info
found this link that answered my question.. hopefully this helpful
http://www.350z-tech.com/zwiki/Part:Springs
Kelvin Style006
May 23, 2016 03:47 AM
Rose M
Sep 30, 2015 05:31 AM
