Requesting opinions on new tire/rim setup dealing with susension
Old Aug 20, 2008 | 09:10 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
*Posted this in Suspension forum but no responses....will try in the general forum here....
OK....here's my situation...didn't know whether to post here in Suspension or in Wheel subforum as it pertains to both....
1. I have Work Varianza Schwert SC2 rims on order from Japan which should get here sometime in September according to vendor (woohoo!). They are 19x9.5 and 19x10.5's offset +17 all around.
2. I plan on using Toyo Proxes 245/275 for the Work Wheels.
3. Currently, I have Hotchki Sport Coils which, according to the manufacture's specs drops the stock height 9/16" in the front and 15/16" in the rear. I have not done an alignment nor have I installed a camber kit or A arm since I dropped the car because I couldn't find a place who could do custom alignment locally until recently.
4. I have bought Cusco A arms for the front and SPC camber arms for the rear but have yet to install them.
5. Currently, I have a 2004 G Coupe non-Brembro running on the stock 18"s with Toyo Proxes.
Here's where I need opinions from my g35driver brothers...
Should I:
1. Scenario 1: Keep the car as dropped. Have them install Cusco A Arms, SPC camber arms, roll the rear fenders, install Work and Toyos, align the car.
Est. Cost: Installation 2 hrs labor for A Arm installation, 2 hrs labor for SPC camber arms, 2 hrs labor to roll 2 fenders, cost to mount/balance tires/rims, custom alignment
**this is what I would ideally love to do but I know this would cost the most
2. Scenario 2: Put the stock springs back on, possibly not needing to do the Cusco A Arm and SPC camber arm installation. Also, I wouldn't necessarily need to roll the rear fenders with the new tires/rims to avoid rubbing since it will be at stock height. Install Work and Toyos, still custom align the car.
Est. Cost: Reinstallation of stock springs 2-3 hrs. labor, cost to mount/balance tires/rims, custom alignment
**With putting on 19"s, putting car back at stock height wouldn't look that bad I'm guessing. Also, I wouldn't have to risk cracking the paint with rolling the fenders. I could save on 4 hrs of installation labor costs by avoiding installing the camber arms and A arms and 2 hrs labor costs on having the rear fenders rollled.
As you can tell, I have tried to reason this out balancing costs with aesthetics with avoiding risk of cracking paint with rolling the fenders, etc etc. For those speaking from your experiences, will a dropped stance that is 9/16" in the front and 15/16" in the rear make that much of an aesthetic difference? I know most will say its personal preference but just looking for some $0.02 on what scenario others would consider.
Thanks in advance....
doc
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
