Do our OEM brake pads use/come with shims?
Old Aug 31, 2008 | 12:07 PM
noooorb's Avatar
03 G35 sedan in particular?
background:
I had a mechanic change my brakes with OEM Nissan pads, but they squeak once warmed down when going from 5 to 0mph. I checked them out today and I noticed that there are no shims installed, and all I see is the blue OEM Nissan brake pad.
Old Aug 31, 2008 | 03:28 PM
xnyc's Avatar
call dealer parts department and ask them if shim kits come equiped on your car.
Old Aug 31, 2008 | 05:57 PM
noooorb's Avatar
Ok I guess it does and I'm gonna have to order:
N1061-187837
Infiniti G35 3.5 4dr 2WD Brake Hardware Kit
Front incl. pad shims (1 per car)
OES-N1061-187837
Old Sep 1, 2008 | 11:48 AM
AARONHL's Avatar
Use a new brake shim kit, go to the Infiniti dealer for that.
Old Sep 2, 2008 | 11:34 AM
Q45tech's Avatar
The elastometric [rubberized] coating on shims changes with heat and effectively wears out. If as new is desired then new shims with every pad replacement.
miata007
Aug 17, 2015 04:36 PM
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
