is 28 pistons over-kill?
Old Sep 1, 2008 | 01:26 PM
mIKE's Avatar
Originally Posted by sheplex02
hahahaha!!!! thats not exactly what i was worried about.. but that brings up my point of uselessness.. this car will be driven alot and will see track time and strip time.. i also will be doing long distance rallies..
I doubt you'd need more than a well designed 4 front 2 rear system. You'd need some serious power upgrades before you need additional braking power.
Old Sep 1, 2008 | 01:53 PM
bigc's Avatar
Wings Nation
a 6/4 setup is all you'll probably ever need. and some brake kits are better than others.
Old Sep 2, 2008 | 11:17 AM
sheplex02's Avatar
thats just it.. i will be getting major power in about 8 months.. +500rwhp is my goal..
Old Sep 2, 2008 | 11:18 AM
jjyellow's Avatar
Do it just for the BLING BLING
Old Sep 2, 2008 | 01:26 PM
waijai's Avatar
i.love.gold
G3 Motorsports brake pads on OEM rotors performed flawlessly at the track on the G3 G35 coupe track car. I think the driver, Jeff Harrison (NASCAR & Enduro), went through 50+ laps giving people rides in the car and tearing the $hit out of everything. Barely any brake fade...surprised every single member of the DFW G35 club that was there that day.
So yeah...just replacement PADS was sufficient in a heavy duty track session.
http://www.grubbsperformance.com/servlet/Detail?no=3072
Old Sep 10, 2008 | 12:04 AM
n1cK's Avatar
G35 6MT
i like that anchor, it's awesome
anyway, be careful about which brake setup you choose. if you get a rotora setup, just remember that you will be stuck with THEIR pads until someone decides to make a compound in their shape. as far as i know, they do not have a standard FMSI number meaning their pads are proprietary.
moog, your buddy may be a pro, but he's just one driver, and if i understand it, on just that one car. i'm no pro, but there is no "end all" brake pad that will suit all applications. you really have to look into your application and find a pad compound suitable for YOU.
there are so many factors to consider, such as where you will drive the car the most often, are you willing to purchase more than one type of brake pad to switch from a street to a track setup (and back), what kind of power are you pushing, what is your vehicle weight, etc.
another misconception is that the more pistons that you have in your caliper, the greater your "braking force" is going to be. this is not the case. auto engineering is not one of my best subjects, but braking force is proportional to the piston area. in other words, unless the piston area of the 8 piston caliper is larger than the piston area of a 4 or 6 piston, then the 8 piston will perform no better. sometimes it could be a worse performer because of the increased flexing that could happen in a caliper because of it's size and/or cheaper material used.
a great reference is the june 2008 issue of grassroots motorsports magazine. let's not even get into brake boosters and master cylinder bore sizes....
Old Sep 10, 2008 | 01:06 AM
badtziscool's Avatar
That is a very valid point. If a car's brake system can only pressurize the system to 1500psi, then a single piston caliper with 100sq in area will exert a force of 150,000lbs. Then on the same system, if you had an 8 piston caliper with 80sq in area, it will exert a force of 120,000lbs. So the single piston system can exert more friction and thus stop harder. But, given that a single piston that large can't apply that force EVENLY over the brake pad, you'll start developing hot spots due to the flex in the pad and this in turn could reduce frictional forces and thus hurt braking performance.
Old Sep 10, 2008 | 12:23 PM
sheplex02's Avatar
wow very good info!! this is more what i was lookn for!!
well what i think im going to do is just go get a brake service for now and then when i get rim and tire package and suspension system im just gonna go get the OEM brake package (front and rear) from the G37S and get some EBC rotors and pads..
i think it look really good too cuz i have a DG coupe and im getting TENZO type Ms in gunmetal, so the silver calipers will stand out really nice..
Old Sep 10, 2008 | 01:03 PM
nghiars's Avatar
or you can even find the brembos off an 03-04 6mt coupe and be done with it.
Old Sep 10, 2008 | 02:02 PM
sheplex02's Avatar
my problem with the brembos is i dont like the gold, so id have to have them painted.. and id have to plus size the rotors and idk.. i like the updated system better..
Old Sep 10, 2008 | 02:10 PM
Jeff92se's Avatar
Red Card Crew
Looks like you want bling more than performance.
I'd ask for brake dist and brake bias data before considering ANY kit. Good luck on getting that info
Old Sep 10, 2008 | 02:15 PM
Drewer's Avatar
Old Sep 10, 2008 | 02:37 PM
nghiars's Avatar
sounds liek jeff might be right and there's nothing wrong with wanting the bling. Im sure the 28 piston set up would definitely turn heads but the reason i mentioned the brembos was that they are great for DD and track plus you can buy them and have them powdercoated any color you like for much less than the setup you were looking at.
Old Sep 10, 2008 | 02:42 PM
sheplex02's Avatar
yeah.. im not going with the 28 piston setup anymore.. would look sick as hell but its not needed..
Old Sep 10, 2008 | 02:44 PM
  #30
sheplex02's Avatar
for $2,400 i can get the G37S setup.. for an additional $1,100 i can get the EBC rotors and pads and some braided lines..
