larger rotor upgrades for brembos?
Old Sep 19, 2008 | 06:08 PM
badnblk's Avatar
anyone know of any upsize rotor upgrades for the factory brembos? i wanna go to 15in front rotor but keep my brembo calipers.
also has anyone fabricated this themselves using larger rotors made for another car and fabricating new caliper brackets?
Old Sep 20, 2008 | 02:30 PM
Q45tech's Avatar
The shape [curve] of rotors, pads, and caliper body must match the curve [diameter] of rotors.
Old Sep 22, 2008 | 04:23 PM
G35fromPA's Avatar
Just mounting the caliper further outboard on a larger rotor would throw off the factory brake bias and you would end up with poorer braking and longer braking distances. Not a move I'd recommend.
Old Sep 23, 2008 | 08:09 AM
Gilley's Avatar
I'm not aware of any Brembo caliper extensions.
You need to go to a BBK if you want larger rotors.
Old Oct 15, 2008 | 02:00 AM
OG35Driver's Avatar
Brakes
For one piece upgrade do Brembo slotted and you will get better braking and the zinc coating looks cool with the OEM calipers. For better heat capacity and cooling do Stop Tech 2-piece slotted. Pricey but great for both braking and heat capacity.
Old Oct 15, 2008 | 03:44 AM
in2win's Avatar
two piece will also dro psome weight at each wheel
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
nissandrifter32
Dec 22, 2015 04:28 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
NJ6MT
Sep 10, 2015 08:40 AM
