Inner thread wear, How normal is this?
Old Sep 25, 2008 | 07:36 PM
pczavala's Avatar
Front Passenger side
Front Driver Side
Well i have a 2007 Coupe, and I was reading up on inner thread wear, some people say its normal but seriously is it this bad??? both wheels have inner wear one more than the other, any recommendations on how to fix?? I hear aligments are not really worth it for this car? The wheels only have about 20K miles in them.
Old Sep 25, 2008 | 07:41 PM
BlueDevilBAMF's Avatar
Well people say the alignment "isn't worth it" because the front camber is not adjustable on the coupe (at least not on '04... I would hope they changed it by '07 but I don't know that they did).
20K miles is actually pretty decent life out of a set of low-profile tires. The stock Bridgestones only get about 15K-20K or so on average from what I've seen.
There are aftermarket front camber kits (e.g. SPC) that you can purchase if you really are worried about it. But, from the looks of your tires after 20K even on the outside, it's only net you an extra 2-3K miles at best. If it's worth it to you then go for it.
And you're right - your passenger side tire is really bad. Did you ever have it aligned in those 20K miles?
Old Sep 25, 2008 | 07:45 PM
codemonkey's Avatar
Whoever told you that obviously didn't see your tires. Get your alignment checked.
Also, what PSI do your keep your tires inflated to and how often do you check/refill?
redlude97's Avatar
What are your current alignment settings?
Old Sep 25, 2008 | 07:46 PM
pczavala's Avatar
nope never had it aligned, i got the car brand new back in February of 07, the only thing ive done to it was change the wheels to some Foose DF-5, never really thought i would need an aligment that soon.
Old Sep 25, 2008 | 07:47 PM
JOKER's Avatar
CLUB MODERATOR
your alignment if FUCKED UP
You should get some wear but not that crazy.
deff need to get the alignment done once you get new tires.
pczavala's Avatar
I try to keep them at 40 PSI, i check pretty often, they have never been lower that 32-35 PSI
Old Sep 25, 2008 | 07:57 PM
OSKIRE's Avatar
that tread wear is crazy...
i did 38k on my stock tires and FINALLY changed them out last week.
Old Sep 25, 2008 | 08:01 PM
codemonkey's Avatar
Is there a reason you're keeping them at 40? That's a little high. You'd be good keeping them at 34/35. Over-inflation could have aggravated the wear problem.
Old Sep 25, 2008 | 08:05 PM
dofu's Avatar
20 Year Member
You shouldn't need to adjust front camber unless you've dropped the car.
Either way, the camber does not matter here... toe eats up tires, not camber, so it's the toe that needs to be adjusted anyways.
Old Sep 25, 2008 | 10:03 PM
pczavala's Avatar
No reason really, when i had them at 35 they looked a little low on air to me. I dunno just me i guess
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
tiguy99
Mar 1, 2016 11:42 AM
Depravity
19 Inch
55
Oct 16, 2015 01:36 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
