Adjustable toe arm and camber kit?
Old Oct 4, 2008 | 06:40 PM
repin_LB's Avatar
what do they do? i read the info on them but all they say is SAVE THE WEAR ON YOUR TIRES. do i need both or can i just get the adjustable toe arm and not the camber kit or visersa?
Old Oct 5, 2008 | 04:42 PM
niceguy's Avatar
They both control different things. The camber is where the tire leans in or out and wears the inside or outside edge of the tire. Toe in/out is where the tire actually turns to the inside/outside. Not sure if I am explainging this well enough, but bottom line if you are lowering the car, you need the camber for sure.... and the toe bolt comes with the kit, so it's a win/win situation.
Hope this helps.
Old Oct 5, 2008 | 09:35 PM
repin_LB's Avatar
thanks you. helped alot. yea im goign to order my camber kit now
Hope this helps.
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
linedr89
Aug 17, 2015 05:11 PM
socalg35x
Aug 7, 2015 09:36 AM
jimNC
Jul 25, 2015 05:47 AM
nascarbuff17
Jul 16, 2015 10:23 AM
