Pics with Tein Basics with Tein recommended height?
Oct 6, 2008 | 10:45 AM
I just installed my tein basics and I followed Tein's recommended height adjustment for the front and rear to get the best results with the provided spring rates, and for some reason my G looks too low. I have searched, and have seen a couple of pics of people with tein basics but they don't specify if they followed the guidelines of Tein's specs for the height adjustment. I will post pics later of mine to compare. Anyone have pics of their setup with the recommended heights from Tein.
Pics with Tein Basics with Tein recommended height?-dsc_0057-10-.jpg   Pics with Tein Basics with Tein recommended height?-dsc_0055-12-.jpg   Pics with Tein Basics with Tein recommended height?-dsc_0050-16-.jpg
Reply 0
Oct 30, 2008 | 03:56 PM
here are mine, car isn't clean but it gives you an idea. One side looks lower then the other side. The passenger side front is slouched even though the front was measured to the millimeter, double checked. Is the G35 chassis built to incorporate the driver. So that it looks lower on the passenger side but when the driver sits in it evens out?
Reply 0
Oct 30, 2008 | 04:19 PM
Go lower
Reply 0
Oct 30, 2008 | 04:33 PM
Thats almost perfect IMO...it would look better lower but you will scrape a lot. Thats about where mine sits.
Reply 0
Nov 2, 2008 | 03:49 PM
I'm scraping now. It is becoming annoying to have to worry about where I might scrape and where not to. My rear rubs on small dips and sharp turns. I might actually raise it and even it out.
Reply 0
Nov 2, 2008 | 04:08 PM
Def go lower!
Reply 0
