What Spring to use?
Old Oct 9, 2008 | 01:01 AM
408stang's Avatar
What Spring to use?
I have 06 sedan. Buying 20's offset for it.
What spring can I use to not have to worry about camber issues or buying anything else? Just want a clean drop that is not to aggressive.
btw. wheel shop says I need to run a small spacer in rear and roll fenders.
I have done alot of research on this topic, but there is too much info to choose from.
Thanks for the advise in advance.
Old Oct 9, 2008 | 10:33 AM
xjonmo's Avatar
350z springs or h-tech
Old Oct 9, 2008 | 10:40 PM
az1anbeethoven's Avatar
why did the shop tell you that you would need spacers? what specs are the rims?
Old Oct 11, 2008 | 03:29 PM
408stang's Avatar
spacer
shop stated I might, but didnt think so. I guess I am going to just have to found out how they sit after I put them on. Manufactor states it should be ok. Might have to role 1/4. No problem because I work in the Body shop industry.
Old Oct 11, 2008 | 03:31 PM
408stang's Avatar
Can I get away with running a spring only? Is there any other mods I would HAVE to do to make it work?
Old Oct 11, 2008 | 04:08 PM
SteveBlake's Avatar
A spring only will be fine, especially with the mild drop you would be acquiring.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Chauzilla
Sep 27, 2015 04:34 PM
