need help finding camber kits!
Old Oct 9, 2008 | 02:26 PM
Ji 35's Avatar
Recently, I've installed 350z H-Tech on my G35.
I need to find the right camber kit for my car but I am totally lost to what I need to get.
I have -1.5 left and -1.8 right front cambers.
A lot of people seem to go head toward SPC.
suggestions will be greatly appreciated!
Old Oct 9, 2008 | 02:36 PM
fresh_06'G35's Avatar
i had the same problem when i lowered on the eibach pro-kit
everyone i asked recommended the SPC kit so i just went ahead and did it so i didnt wear out my tires.
Old Oct 9, 2008 | 11:18 PM
urban's Avatar
The revised ones from SPC are the best.
Old Oct 10, 2008 | 12:11 AM
spades_03's Avatar
I just ordered the SPC kit from THMotorsports check out this link
https://g35driver.com/forums/suspens...tires-___.html
and i think they will match prices just give them a call or contact them on AIM they shipped the same day A+++ service.
Old Oct 10, 2008 | 09:21 AM
eZg's Avatar
eZg
SPC camber kits
I just had both front and back intalled a couple weeks ago. There seems to be a problem that some guys, including me, are having with the ABS sensor brackets. If the 13mm bolts that are used for the bracket are overtightened, or if the bracket is bent during install ABS, VDC, and slip lights come on.
I even gave my installer a head's up about thise problem and still had to go back to the dealership three times while they sorted it out.
Not to be a 'Debbie Downer' but I'm not sure if Cusco, SPL, or EVO arms might be worth the extra money.
Old Oct 10, 2008 | 10:34 AM
eZg's Avatar
eZg
oh yea....
I have heard Kinetex front control arms are DEFINATELY not the way to go. Read a couple posts by people who have had them snap at a weld. One guy had his 10 year old son in the car with him and had an accident when the contol arm gave way.
How do you like your Tein springs? I'm getting tired of researching the difference between those for the 350Z...used on the G35 coupe and those specifically for the G35. I'm looking for between a 1"-1.5" drop and would like a little more stiffness but not so much that my 4 year old's teeth to wiggle loose. She is actually VERY critical of my driving
Old Oct 10, 2008 | 11:09 AM
silver g's Avatar
For the front I would go with SPL. For the rear I would use either SPC or SPL. SPC's are cheaper and come with the Toe Bolt.
Old Oct 10, 2008 | 11:48 AM
ND#7G35X's Avatar
Cool Camber Kit
I have a question for you guys I have a 2007 G35x sittin on Tanabe DF 210's.
The front is dropped 1.7 and 1.5 in the rear. I'm having a tough time finding a Camber kit. I had no idea the drop would be so low. I love it, but really want to straightin out my rear tires!
Old Oct 16, 2008 | 02:49 AM
Ji 35's Avatar
I really like my springs. enough drop for me. If you are looking for more than a 1" drop, then I wouldnt go with the z H-techs. something else. may be something like s-tech. But, I really like my drop and how it looks with my rims.
Old Oct 16, 2008 | 02:59 AM
tragedycat's Avatar
I have SPC revised front and rears, didn't end up using the spacers for the fronts. No ABS or knocking problems so far (but just got the fronts put on yesterday).
Old Oct 17, 2008 | 01:47 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
^same situation, but I have been running just fine for over 10K miles.
can't go wrong with the SPC front and rear. good luck!
Old Oct 17, 2008 | 01:55 PM
eZg's Avatar
eZg
So you guys with SPC kits....
what camber are you running? Dealer that installed mine wouldn't drill for the Toe bolts in rear and didn't know what to set camber at besides stock specs.
Of course, people (including me) have had uneven tire wear at spec settings.
I was thinking about -.7 to -.9 front and about -.5 in rear but that is info gathered thru searching....I have no idea what would be ideal!?!
paolojericho11
Sep 11, 2015 07:08 AM
socalg35x
Aug 7, 2015 09:36 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
