Compression rod / Lower control arm ... little confused HELP
Old Apr 20, 2009 | 12:30 PM
  #31
WILLIE BEANS's Avatar
bump for good info in this thread ..
Old Apr 20, 2009 | 01:12 PM
  #32
terrasmak's Avatar
G Sedan
Good info , were all screwed for now. The Nismo and Whiteline bushing are both on backorder till sometime in may.
Yup both of mine are blown, i noticed when i was putting my car back into street trim.
Old Apr 20, 2009 | 01:30 PM
  #33
that sucks ..
bump for a different supplier?
Old Apr 21, 2009 | 02:28 AM
  #34
terrasmak's Avatar
G Sedan
that sucks ..
If you find one lit me know. I've searched high and low and no one has them.
Old Apr 21, 2009 | 02:38 AM
  #35
DDD*G35's Avatar
http://performanceshock.com/index.ph...ain_page=index
Check it out.........
Old Apr 21, 2009 | 09:11 PM
  #36
terrasmak's Avatar
G Sedan
Originally Posted by DDD*G35
They're kinda sold out
Old Apr 23, 2009 | 07:00 PM
  #37
OCG35's Avatar
subscribed for transverse link bushing source... mine is shot - my alignment guy has press... Performance Nissan (mynismo) is within driving distance - I guess I wait till May unless someone finds a source
Old May 15, 2009 | 05:18 PM
  #38
Dxplicitone's Avatar
Havent been around since i sold my G35... i will tell you when i ordered mine they were out of stock also. Told me it would be a month wait, after i ordered it was actually only a 2 week wait and keep in mind if you wait till its "in stock" they will fill the orders that are already waiting before they get to you. So you might as well order the ish now and just get in line since you know that you need it.
Old May 15, 2009 | 08:18 PM
  #39
terrasmak's Avatar
G Sedan
Orderedthru 350zmotorsports.com and they are on the way
Old Jul 26, 2009 | 01:08 PM
  #40
dovla's Avatar
I bought mine from http://www.jscspeed.com/350z/suspension/wlp_bushings.htm
I have access to hydraulic press but couldn’t find suitable size ID & OD piece of pipe to push out old bushings. What are you using to push bushing without damaging the arm?
Old Jul 26, 2009 | 01:57 PM
  #41
Jining's Avatar
Yea i had that problem as well. I had to grind down a bearing race to press mine in.
Old Aug 7, 2009 | 05:37 PM
  #42
Use a socket... its the easiest and most common.
Old Aug 9, 2009 | 08:29 PM
  #43
paolotonzini's Avatar
heres a link if u still lookin i found it after i spent 400 to replace that lower control arm the shop screwed me but jus a learnin exp i guess
http://www.g35nyc.com/forums/showthread.php?p=421577
Old Aug 9, 2009 | 08:42 PM
  #44
OCG35's Avatar
^^^ good find
Might be easier to link it this way though:
http://www.z1auto.com/prodmore.asp?m...ng&prodid=3783
Adam (Z-1) is a good guy – very knowledgeable… his shipping is real fast too!
Old Aug 28, 2009 | 09:27 AM
  #45
electricjer's Avatar
Is this for a pair of bushings that would cover both the right and left side? I am just wondering if I need to order 2 to do both sides done.
Originally Posted by OCG35
^^^ good find
