Car Pulling to the Right
Old Oct 23, 2008 | 01:40 AM
austinm22's Avatar
Question Car Pulling to the Right
So not too long ago I clipped a curb with my g35, had new wheel put on, new alignment done, new wheel assembly. Well i got it back from the body shop and the car just pulls slightly to the right, I took it back but they couldn't figure it out, anyone have any suggestions?
Old Oct 25, 2008 | 11:27 AM
maomao's Avatar
just a guess but you may want to check to see if the wheel bearing got messed up on the wheel that hit the curb. I had a similar issue (horrible vibration) and my wheel bearing was the culprit. Mine was so bad that when the car was jacked up I could jiggle the wheel back and forth with the hub staying in place.
Old Oct 30, 2008 | 09:20 AM
nsid23's Avatar
I think I have the same problem, where's a good place to find a new wheel bearing?
Old Oct 30, 2008 | 03:00 PM
maomao's Avatar
What I did was actually buy the complete hub. If you buy the bearing by itself you'll have to get it pressed into the old hub. I bought the hub at a Nissan dealer. It was aprox $270. Infinit for the exact same part was somewhere around $350. Hope this helps!
Old Nov 4, 2008 | 07:26 PM
austinm22's Avatar
Found this guys.
http://www.trademotion.com/partlocat...layCatalogid=0
Old Nov 4, 2008 | 07:39 PM
cremaster's Avatar
your front camber settings may be off. mine were and i got a 'cradle/subframe shift.' problem gone.
Old Jan 29, 2009 | 03:00 PM
Preston's Avatar
check your rack and pinion. My car was donig that and try to replace everything and I did. Later I found out that rack and pinion was damaged. After they replaced, problem was solved.
Old Feb 10, 2009 | 12:29 PM
broke_as_ajoke's Avatar
i have the same problem right now.. after i hit a curb.. i'm gonna take it to the alignment shop and see if they can fix it.. i hear a roaring when driving.. also my tps light is on now.. (i have put air in all the tires and it still will not go off)
Old Feb 13, 2009 | 10:39 PM
ninjlao's Avatar
You might have bent your arms just slightly. To the point where the guy aligning it didnt notice but it happened to my friends car.
Old Feb 21, 2009 | 06:56 PM
AARONHL's Avatar
How can you tell if the rack and pinion is damaged?
Old Feb 25, 2009 | 10:56 PM
jin22gt's Avatar
I went to a shop(Mavis) to get an alignment done today. Had it done and it got worse! My car goes to the left even tho the steering wheel is straight! I took it back and the alignment machine said the toe is way out of place. They just had it aligned, but I dont understand how could it go bad in just couple of miles? They tried it again but couldnt get it right. Refunded me the money back.
What could the problem be? they didnt know what the problem was.! wtf kind of shop is that.
Im planning to go to a different shop tomorrow.
Hasanbaloch
Feb 29, 2024 08:45 PM
rezendvous420
May 31, 2020 01:26 PM
will091195
Jul 27, 2015 09:19 PM
itschuckster
Jul 25, 2015 08:07 AM
