Rear camber still off after camber kit installed??
Old Nov 7, 2008 | 12:30 AM
BigVicG35's Avatar
Hey guys i need help.. i had my G coupe lowered on Eibach pro kit springs. i have the front and rear camber kits installed. My front got aligned but my rear still has a neg camber, what could it be?? i went to two different shops and both told me that i need to raise my rear like 0.5" which is BS .. i appreciate the help..
Old Nov 7, 2008 | 05:14 AM
redlude97's Avatar
some negative camber is normal and desired. What are you current specs?
Old Nov 7, 2008 | 10:57 AM
Q45tech's Avatar
Each 1.0" of body lowering usually adds 0.83 degrees of negative camber on a 26" tire.
Why you do an alignment and vary the camber to see the correctable range before wasting the enviroment on lowering. Wasting as in tire wear and cost of corrections.
Old Nov 8, 2008 | 02:04 AM
BigVicG35's Avatar
Currently i am at negative 3 degrees??
Old Nov 8, 2008 | 11:39 AM
CreativeDesignZ's Avatar
sounds like you didnt install your camber kit properly or the shops ur going to are filled with morons...
edit: clearly u are not bringing your car to a place that specializes in lowered vehicles, you may want to try that before bringing your INFINITI there. you dont drive a slammed civic hatch...
Old Nov 20, 2008 | 04:42 PM
BigVicG35's Avatar
ok, well supposedly these shops do these cars all the time yet they cant figure it out... do any of you know of any good shops ranging from Riverside to Temecula?? and a good alignment shop too.. Thanks
neight
Steering & Suspension
Aug 7, 2015 02:48 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
