SPC rear camber arm help
Old Nov 10, 2008 | 07:32 PM
SilverG123's Avatar
So i was putting in my rear camber arms and i sort of messed up. I was late for work and i forgot to read the instructions. Well instead of making the toe slot by the spring bucket longer i did it on the camber arm slot it self. I put the toe bolt in the camber arm slot. if i do it the way it is supposed to be done, by putting the stock camber bolt back into the camber arm slot, and widen the toe slot and put the toe bolt that came with the camber kit back in, will their be any problems with widening the camber arm slot? i feel so stuiped thanks for the help
Old Nov 10, 2008 | 11:50 PM
G35Papa's Avatar
It will be fine. The camber arm slot basically stays stationary so once the OEM bolt is back in place, it will just stay there anyways. All the adjustment will be done with the camber arm.
Now you can sleep tonight
Old Nov 11, 2008 | 12:45 PM
SilverG123's Avatar
Thanks for the help man, i read this too late so all probably sleep good tonight.
Old Nov 11, 2008 | 12:48 PM
redlude97's Avatar
Just make sure you check them occasionally, since they now have less area to grab onto when torqued down
Old Nov 11, 2008 | 06:51 PM
SilverG123's Avatar
all make sure to do that. When ever i go in a strait line the car feels like its going to spin out, its frightning just going down the street.
Old Nov 12, 2008 | 04:43 PM
SilverG123's Avatar
I put everything in the right spot and everything came out good, thanks for all the help everyone.
Old Nov 13, 2008 | 12:58 AM
G35Papa's Avatar
No problem...glad it all worked out
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
cbax
Aug 17, 2015 07:41 AM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
