Aftermarket shocks
Old Nov 20, 2008 | 10:43 AM
vipers's Avatar
Aftermarket shocks
I have a 2004 G35 coupe and I'm thinking about buying Espelir springs from a 350Z which will lower my car a good amount. I have about 50,000 miles on my car, should I buy aftermarket shocks? I've searched the topic and I've seen mixed opinions. I don't want to spend more than I have to, but I also want to stay safe as this is my DD.
If I need new shocks, what would you recommend? Koni is very expensive (at least for me)...are there any that aren't as much? Thanks.
Matt
Old Nov 20, 2008 | 10:59 AM
KSWAY's Avatar
Tockico HP series struts. http://cgi.ebay.com/ebaymotors/TOKIC...Q5fAccessories
For the price i don't think you can beat those.
Old Nov 20, 2008 | 02:37 PM
vipers's Avatar
Anyone have experience with these?
Old Nov 20, 2008 | 08:43 PM
EL-EE-ES's Avatar
tokico d-specs!
Old Nov 25, 2008 | 09:55 PM
nice_camel_toe's Avatar
I just installed them(HP's for G35 application) with Tein H-Tech's (350z application) last week and think their great. The whole setup feels "sportier" without the harsh ride.
I was in the same predicament you were in as I have about 56K miles on the car and didn't want to spend a whole lotta $$$. I went with the Tein / Tokico combo for $460. Not bad for what you get. Not a lot of people had this set-up so I decided to take a plunge as I had great results in the past(91 MR2 with Eibach Prokit w/ Tokico Illumina's, and (97 240sx with Tein S-techs with HP's).
The way I see it, when we do decide to change and or come up with the cash we can prolly sell our setup for at least half and upgrade to coilovers at a later date.
Old Apr 7, 2009 | 02:57 PM
vipers's Avatar
Bringing this thread back from the dead...I'm going to finally order these shocks soon. I will let you all know my experience with them.
Matt
Old Apr 7, 2009 | 03:07 PM
Jeff92se's Avatar
Red Card Crew
Dude. type Tokico D spec or something in the search engine. Probably over 50% of those that are on lowering springs only run these.
Or read the sticky up top.
Old Apr 7, 2009 | 04:45 PM
vipers's Avatar
Yeah I've only heard good things. I'm buying Espelirs from my friend and then I'm buying the struts.
Old Apr 8, 2009 | 12:31 PM
Gsedan35's Avatar
Espelir 350Z progressive springs 10mm drop F&R
Spring rates 386/515 (rear rate IMO is too high for all oem shocks, Z or G)
Tokico has outright said, "D-spec shocks have a spring rate limit of 450lbs", being that the HP is a lessor shock, it is not going to have a higher rate limit then the D-spec shock.
IMO,
1. Pick a different spring
2. Run the Espelir front springs, but install oem Z revised rear springs on cut down oem upper spring seats.
3. Ignor Tokico's advise and run 350Z D-specs (meaning skip the HP's).
Old Apr 8, 2009 | 11:11 PM
vipers's Avatar
IMO,
I've recently been considering buying a set of 06+ headlights before doing a drop...I have some condensation that I would like to get rid of.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
