Question: Alignment specs after SPC front and rear and Eibach and Tok D
Old Nov 20, 2008 | 03:18 PM
Rival's Avatar
Dealer still wasn't able to get it exactly into spec range. It pulls straight and smooth, but I thought with the SPC kit I should be able to get it into spec? Really don't want to smoke through my PS2's
Supension mods: Eibach Prokit & Tok Dspecs SPC Front and Rear kit
Here are the results. Thoughts?
Front Left:
Camber: After: -0.9* Before -1.1* Range: (-1.2* to 0.3*)
Caster: After: 8.8* Before 8.9* Range (7.3* to 8.8*)
Toe After: 0.04* Before 0.07* Range (0.00* to 0.08*)
Front Right:
Camber After -0.6* Before -0.4* Range (-1.2* to 0.3*)
Caster After 9.1* Before 9.2* Range (7.3* to 8.8*)
Toe After 0.5* Before .03 Range (0.00* to 0.08*)
Front
Cross Camber After -0.4* Before -.08* Range (-0.8 to 0.8*)
Cross Caster After -0.4* Before -0.3* Range (-0.8 to 0.8*)
Total Toe After 0.09* Before .10* Range (0.00* to 0.16*)
Rear Left:
Camber After -1.3* Before -3.3* Range (-1.8* to -0.8*)
Toe After 0.58* Before -0.52* Range (0.00* to 0.22*)
Rear Right:
Camber After -1.2* Before -2.5* Range (-1.8* to -0.8*)
Toe After 0.10* Before -0.58* Range (0.00* to 0.22*)
Rear
Cross Camber After 0.0* Before -0.7*
Total Toe After 0.68* Before -1.10* Range (0.01* to 0.43*)
Thrust Angel After 0.24* Before 0.03*
Old Nov 20, 2008 | 04:21 PM
GLuXuRy's Avatar
dealer and aftermarket products .. dont work well together
Old Nov 20, 2008 | 04:38 PM
Rival's Avatar
If the rear toe was better I would be happy, but that .58* worries me.
Old Nov 20, 2008 | 08:53 PM
EL-EE-ES's Avatar
very true...take it to an alignment shop
Old Nov 21, 2008 | 06:25 PM
MPK1232's Avatar
how much did the dealer charge you for the alignment?
Old Nov 21, 2008 | 07:32 PM
Rival's Avatar
$89 plus they fixed a broke wheel lock and took off the nut and installed a spacer.
Old Nov 21, 2008 | 07:37 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I agree....
You need a good alignment shop.
....not always easy to find. (a good one)
Old Nov 21, 2008 | 07:44 PM
bigc's Avatar
Wings Nation
yeah, get that rear toe fixed or you're going to eat through that tire in a hurry.
Old Nov 25, 2008 | 03:19 PM
GLuXuRy's Avatar
who installed the rear spc toe bolts ?
Th611
Oct 27, 2015 03:48 PM
EPG35
Aug 16, 2015 04:52 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
