help please so irritated
Old Nov 21, 2008 | 10:55 AM
carbon_g35's Avatar
hi, guys well i have a big problem i have works vs-xx the size for rear (were the problem is driving me nuts) 20x10.5 5x114.3. I just went through a set of rear tires like in three months now im on my second set and i can already see im still having the same problem even after i went to get a new alignment, firestone said they can only put the specs to the stock specs if i have another set of specs to bring it and they will put it at whatever i want so my question is what should i do should i get something for my suspension or what please help someone
Old Nov 21, 2008 | 12:03 PM
EL-EE-ES's Avatar
what is your spring/coilover setup? stock/lowered?
Old Nov 21, 2008 | 12:10 PM
carbon_g35's Avatar
stock
Old Nov 21, 2008 | 12:14 PM
brianmfournier's Avatar
My coupe ate tires with stock 18's. The original michelins made it 17k miles. I think it's just a fact of life with the G
Old Nov 21, 2008 | 12:44 PM
carbon_g35's Avatar
mine did even last til 3k i envy you for making it that long
Old Nov 21, 2008 | 01:03 PM
redlude97's Avatar
post your alignment sheet
Old Nov 21, 2008 | 01:09 PM
Jeff92se's Avatar
Red Card Crew
What tire do you have? If the UTOG is only like 180, you aren't going to get too many miles out of it.
Old Nov 21, 2008 | 01:12 PM
Texasscout's Avatar
If your on a stock supension, the ONLY adjustment is front axle "toe-in".
Are your tire wearing on the inside, feathering, cupping, what?
Old Nov 21, 2008 | 10:57 PM
EL-EE-ES's Avatar
3k? wtf? im at 30k with a ton of tread life still what tires you running?
Old Nov 23, 2008 | 06:23 PM
carbon_g35's Avatar
toyo t13 they only wear out from the inside should i get a rear camber kit????????
Old Nov 23, 2008 | 08:34 PM
redlude97's Avatar
still no alignment specs? How do you expect to get any help?
Old Nov 23, 2008 | 11:55 PM
Texasscout's Avatar
Front specs, last page:
http://www.g35frenzy.com/downloads/2...nual/E/fsu.pdf
Rear specs, last page:
http://www.g35frenzy.com/downloads/2...nual/E/rsu.pdf
Do a search people!
Old Nov 24, 2008 | 04:26 AM
redlude97's Avatar
Originally Posted by Texasscout
How does that help when I'm asking for HIS specs? I know the factory specs
Old Nov 24, 2008 | 07:23 AM
Texasscout's Avatar
Sorry, I don't understand what HIS specs are. If you rerturn it to stock, it should not wear so bad. All G's have a little neg camber.
Old Nov 25, 2008 | 01:51 AM
carbon_g35's Avatar
How Do I Find Out My Specs???????
