Brake pad hooks?
Old Nov 24, 2008 | 03:37 PM
garett7485's Avatar
Help, brake pads
After moving into my new apartment where I cannot work on my car, I was forced to pay someone else to put my new pads and rotors on Saturday. I have an 03 g35 sedan Auto. I noticed that there is a small horseshoe like loop sticking off of the caliper and tab that looks like it should be inside of that loop... but it's not. Sorry, I dont have any pics and haven't noticed any noises or differences in braking but, is this serious? What is it for? I think I can bend it in there without taking the assembly off...
Thanks for your help, hopefully this makes sense.
Old Nov 30, 2008 | 01:39 PM
nitromax's Avatar
if it's the tab on the hardware sticking straight out on the side of the caliper,
then yes it should be hooked into the loop on the pad that sticks out right next to it. the purpose for it is to apply slight return pressure to the pads, pulling them off of the rotors.
Old Nov 30, 2008 | 02:17 PM
EL-EE-ES's Avatar
maybe theyre the cottar pins on the pin that holds the the spring in place
Old Dec 8, 2008 | 07:58 PM
G35fromPA's Avatar
If they are little metal clips that are attached to the pads, then those are the pad wear indicators, and they should be facing the rotor, not the outside of the caliper. Someone put the pads on incorrectly. You need those to warn you the pads are getting close to end of life, unless you are extremely vigilant about watching pad wear.
Old Dec 8, 2008 | 08:19 PM
miltoda's Avatar
is this on the front brakes? That hook on the pad mates up with the caliper assembly to provide you a warning that your front pads are low. Check the service man. you'll see. I would link to it or something, but i'm at work.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
JG_G35
Apr 29, 2016 04:46 AM
alessandro
Oct 8, 2015 09:29 AM
bigmike
Sep 17, 2015 01:58 PM
NJ6MT
Sep 10, 2015 08:40 AM
