What tools to use??
Old Dec 5, 2008 | 07:27 PM
real3997's Avatar
What tools to use??
I'm going to change the front brakes for the first time on my 03 G35. And i was just wondering what tools i would need. I just dont want to pull the tires off and be suprised. And have to put them back on to go to the Hardware store. They are the stock rotors and calipers. Please HELP!!!!
Old Dec 5, 2008 | 08:01 PM
Seymore's Avatar
Strictly from memory, so won't be perfect.
Basics:
You'll need a lug nut wrench, metric socket set (mostly 14 - 22mm), a foot pound torque wrench that goes from 20 to about 100 foot pounds, C-clamp, and a standard screwdriver (to help pry and re-insert clips).
Recommended:
I also recommend a runout gauge and welders clamp (there's too much aluminum to use the gauge magnet), but most don't take these measures.
Other misc supplies:
Brake cleaner, caliper grease, mechanics gloves, and brake fluid. You may need a suction bulb depending on the level of the fluid in your master cylinder and the wear on your existing set of brakes. Finally, a greeny cleaner (or any abrasive non shedding scouring pad) can come in handy for cleaning the hub before reinstalling the rotor and checking for runout.
Hopefully that helps a little.
Old Dec 5, 2008 | 10:36 PM
lexusk8's Avatar
^ Good list Seymore. I would also recommend getting a breaker bar to break loose the sliding pin bolts which hold the brake pads in place. These bolts are torqued in there pretty good for obvious reasons. If you don't have a breaker bar available, you might be able to get by with using a torque wrench to remove the bolts.
Old Dec 5, 2008 | 10:49 PM
UnluckyCharms's Avatar
Dear god, please don't use a torque wrench to break the torque on ANYTHING. Torque wrenches are used to tighten things; using it like a breaker bar will destroy the tool.
Old Dec 5, 2008 | 10:54 PM
speedracerg35's Avatar
good recommendations. don't forget to loosen the cap to the brake resivoir and to retighten it when you are finished.
DRG35R
Jan 31, 2016 07:14 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
TNRocker
Sep 21, 2015 08:36 AM
Cbohannan101
Sep 12, 2015 10:32 PM
