HELP! Knocking/Clicking noise in the front
Old Dec 10, 2008 | 08:30 PM
G35xChicago's Avatar
I have a similar problem to this, but its not so much creaking as it is "clicking" or "knocking" coming from my driver front wheelwell. I have an 05 X sedan. Lowered on z/coupe springs and usually have my coupe 19s on in the summer....just switched back to 17" stockers but still lowered.
Recently ive been hearing this noise usually when im reversing (clockwise turn of the steering wheel) out of my parking spot and turn the steering wheel all the way. This also happens when im going 5-10 mph and do some slight turning as well. Its not very consistent, happens here and there...Any ideas?
Is this struts issue? pillow ball? rack/pinion? Any ideas guys?
Old Dec 16, 2008 | 03:33 PM
rpg35's Avatar
I recently lowered on Z / coupe springs and have a similar noise coming from the front driver side. It happens when slowly to the 5-10 mph range going over rough road and / or slowly turning to the right.
Old Dec 17, 2008 | 09:52 AM
surfwb86's Avatar
Same here. I think it may have something to do with the lower compression rods, my ball joints are torn.
Old Dec 17, 2008 | 10:02 AM
surfwb86's Avatar
A lot of people are having problems with the lower control/compression rods so check those to see if the ball joints are torn.
Also check your sway bar end links, these will be your best bet for the source of your sound.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
rping
Jul 26, 2015 09:53 PM
papo020
Jul 17, 2015 10:30 PM
