Pot Hole!
Old Dec 19, 2008 | 12:03 PM
g35couture's Avatar
Pot Hole!
hi people,recently i had changed my springs to ebiachs coupe lowering springs on my 03 sedan, and yesterday on the freeway (57n) i hit a pot hole on the front driveside. Now i notice when im driving 80MPH+ my car vibrates in the front really bad but when i brake or make a really slight left turn it will stop for 1 second. what could be the problem?
Old Dec 19, 2008 | 12:26 PM
redlude97's Avatar
did you check to see if the wheel was bent or cracked?
Old Dec 19, 2008 | 01:13 PM
g35couture's Avatar
ok i went outside and check the wheels, theres no crack or bend.. so im guessing could it be an aligment?
lexusk8's Avatar
Get your car in to a tire shop and get your wheels road-balanced. The tech(s) there should be able to tell you which wheel(s) are bent and the degree of damage. This is a better way to determine if your wheels are bent when you can't find any damage on the outside.
Old Dec 19, 2008 | 01:31 PM
ttrank's Avatar
Grocery getter
Posted in your other thread too.
My guess is that the rim is bent (could be minor but you will feel it). You also need to have your alignment checked.
Old Dec 19, 2008 | 01:38 PM
az1anbeethoven's Avatar
kinda off-topic, but where on the 57N were you? So i can avoid that pot hole...lol...also got a pic of your drop of your sedan with those coupe eibachs? were they the pro-kit?
Old Dec 19, 2008 | 03:10 PM
g35couture's Avatar
57N close to imperial hwy, two lanes towards the right.. ill post up some pics later when i have time this weekend
Old Dec 20, 2008 | 01:15 PM
Q45tech's Avatar
Demount tires and measure wheels on a balancer [set to grams and fine resolution]. The oem specs for wheels are that they require no more than a single 5 grams balance weight on each inner or outer plane to achieve 0.0.
Many aftermarket wheels [brand new] arrive seriously bent or never came close from factory.
Fix wheels then worry about tires.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
G35xdriver04
Nov 7, 2015 08:31 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
AesonVirus
Engine - Exhaust
Sep 20, 2015 01:54 PM
JustinMKN1
Sep 18, 2015 03:40 PM
