On some rotors there is actually a threaded hole into which you could screw something in and help pop the rotor off.. but the front rotors come off a LOT easier than the rear ones .. just one or two hits with the mallet.
Quote:
so true... the rears dont have the threaded hole, i tried for about 1.5 hours, took a break and came back pissed and hit the rotors like 3 times and they came off (could have been the time they "soaked" but probably more because of hitting them with a bigger hammer) Originally Posted by bythabay
Hey... sorry to jack your thread
But i am in the market for some new rotors as well (front only). My front rotors are starting to cause vibrations upon braking... Guessing i need new rotors and pads... I saw some at this website but they are confusing:
http://www.horsepowerfreaks.com/perf...s/Brake_Rotors
I drive a 05-6MT so no brembo - which rotors from under rotora would I need to order (i just need the fronts). Also looking for pads if you guys have suggestions.
I just bought a set of F/R from DRTsprt in Ma. ...
https://ciscosales.webex.com/ciscosa...hp?J=927006291 .
dofu
close
- Join DateSep 2005
- LocationSilicon Valley
iTrader Positive Feedback100
iTrader Feedback Score(9)
Liked:242 Times in 197 Posts
Quote:
Notice the nice crack in the rotor. This car HAS NOT been tracked.
I emailed StopTech on this and was told that they do not warrent DRILLED rotors AT ALL!
DO NOT BUY DRILLED ROTORS, only get "Slotted" or "dimpled" or both.
BTW, someone suggested that these are "cheap chinese ebay rotors" "the drilling pattern doesn't look like StopTech", well they say "Centric" on the rim. ,,,
Those don't look like StopTechs at all... and plus, even if you wanted better braking, you'd want slotted, not drilled.Originally Posted by Texasscout
I ordered drilled rotors from a vendor here is a pic of one of the rear rotors:
Originally Posted by majorheadache
I just bought a set of F/R from DRTsprt in Ma. ...I just bought a set of F/R from DRTsprt in Ma.
Haha uhh this is a webex session for cisco.
<-- Network Engineer
Texasscout
close
- Join DateFeb 2005
- LocationSouth Texas
iTrader Feedback Score(11)
Liked:2,116 Times in 1,768 Posts
Quote:
Sorry, but they are. I confirmed this with StopTech. They say Centric on them, but Centric owns StopTech.Originally Posted by dofu
