View Poll Results: Which suspension should elrooko buy
HKS Hypermax III
45.45%
Stance GR+
9.09%
BC Racing (8/10)
4.55%
Tein Flex
40.91%
Voters: 22. You may not vote on this poll
What suspension would you buy? - Stance GR+, HKS HyperMax III,BC Racing or tein flex?
Old Jan 13, 2009 | 12:02 PM
elrooko's Avatar
Hey all,
so I have narrowed my selection to 4 options. Have quotes for all of them, just need a bit of a push to figure out which one I should get.
1) HKS Hypermax III Street (9/9)
2) BC Racing (8/10)
3) Tein Flex
4) Stance GR+
I am going to use this pretty much for street driving, car is not my daily driver and I am going to the auto X track about 1 once a month. Which one would you buy?
Old Jan 13, 2009 | 12:30 PM
ttrank's Avatar
Grocery getter
I like Tein stuff so I would go with the Flex.
You do understand how rough these ride since you are using this mostly for street driving? I could not deal with it.
Old Jan 13, 2009 | 01:32 PM
GreenGoblin's Avatar
The goblin resurrection
I have my Tein flex on my car and daily drive it, its not that bad. It is great for the track tho
Old Jan 13, 2009 | 01:41 PM
Triple8Sol's Avatar
The EDFC is an added bonus to running the Teins.
Old Jan 13, 2009 | 08:56 PM
4MeUwill's Avatar
It all depends on what your driving habits and personal preferences are when deciding on coil overs.
I have tried my fair share of coil overs and in most cases I would say go with the Stance GR+ or the BC Racing ones.
In my experience, Tein is all marketing hype and acceptable at best.
The HKS Hypermax are also a lot of hype and are made for HKS by the same manufacturer as a couple of other coil overs (surprising to most).
Bang for buck, stick with one of the the Stance or the BC Racing.
Old Jan 13, 2009 | 08:58 PM
patman530's Avatar
TEIN Flex +EDFC, since it's not your dd. wouldn't recommend it for a dd
Old Jan 13, 2009 | 09:11 PM
ttrank's Avatar
Grocery getter
Wow
I have been in a couple and that is too harsh for me. Once I get a DD and my car becomes more of a toy I will change to those.
Old Jan 13, 2009 | 09:14 PM
roneski's Avatar
Devil's Advocate
Flex is pretty stiff for a daily driver. My GF is always bitchin about it.
Old Jan 14, 2009 | 02:30 AM
armt350's Avatar
I'm running Type flex on my G, Out of your list I would buy it again. Although if I was to choose any right now it would definantly be the KW Variant 2 or 3 depending on how much track use it will get.
Old Jan 14, 2009 | 02:35 AM
ShanesG's Avatar
My list would be exactly how ou have it on your poll, with HKS 1st and Tein last!
Old Jan 14, 2009 | 02:47 AM
B L U E S L A T E's Avatar
Honda Accord
JIC Magic.
Old Jan 14, 2009 | 02:51 AM
Skaterbasist's Avatar
Retired SuperMod
HKS Hipermax III's are freakin' awesome. I have them (SPORT version) and they are great.
Not too many people are willing to spend that kind of money on coilovers but if you want a quality suspension that has been proven to work its magic on the road and the track...then pull the trigger
Old Jan 14, 2009 | 08:34 AM
elrooko's Avatar
Thanks for all the replies guys - let me give you some more background.
I store the car for the winter here in Canada and I have 2 other cars. The G is simply my big toy. I drive it a fair bit in the summer mostly alone, but sometime the wife comes with me, but not often. I track the car almost 1 once a month and the track performance was the main reason why I decided I needed a new suspension - the 03 non-sport suspension simply wasn't up to the task.
I'm not really planning on using EDFC - it seems like more than I need. So long as I can adjust the dampers manually I would be fine with that. Money isn't really an option but I won't be spending Zeal coilover prices. I figured 1700 was about my upper limit. If I can get something for less that meets my needs then great.
I really want a good quality suspension - I don't want creaks or knocking. This was the main reason why I was leaning towards the HKS - I heard they are quite quiet. I have heard hit or miss about BC Racing - some people have the "clunk" others don't. I think they came out with a revised pillow ball mount or something that reduces it but I wasn't really digging into it.
I don't mind a stiff ride, so long as the damping is well setup and not jarring. I'm not planning on taking it off road and the roads around here are not too bad. I want something that is stiff but firm on the roads but performs well at the track.
HTH - thanks again for all the opinons guys - really appreciate it.
Old Jan 14, 2009 | 12:08 PM
armt350's Avatar
fyi, the rear suspension is not able to be adjusted without unbolting the coilover shocks. keep that in mind for your adjustment.
Old Jan 14, 2009 | 12:15 PM
elrooko's Avatar
For which setup? I thought that was the case only with the Tein - hence EDFC?
