Stillen Sway Bar Setting Question
Old Jan 19, 2009 | 09:49 AM
jimmykce1's Avatar
I have installed sway bars on my G35 sedan and have it set to medium front and hard rear. I have been noticing that my car will fishtailing a little going over large bumps and manholes when its wet. I did install new tires on my car a couple of months ago too. Do I have the rear sway set to high? Do I need to put the rear back to medium setting to eliminate this? Please give any suggestions.
__________________
Old Jan 19, 2009 | 07:40 PM
Sentientbydesig's Avatar
Isn't this common knowledge?
Setting your rears high will leave little room for difference between sides. Set the rears to medium to avoid fishtailing.
I would only run Stillens on high or Cuscos if I was drifting. Otherwise there really isn't a point.
Old Jan 19, 2009 | 08:45 PM
G35fromPA's Avatar
In addition, in general, stiffening the rear suspension in relation to the front (i.e. stiffer sway bar, stiffer springs, shocks, etc.) will result in greater tendency for oversteer (fishtailing). Either set the front to hard to match, or set the rear to medium to match.
Also, you have stiffer springs and an STB which contribute to the overall rear stiffness increase.
Old Jan 20, 2009 | 08:36 PM
jimmykce1's Avatar
I am going to put the rear sway to medium on Saturday. I did some research on here and found most sedan owners use the med on front and rear. I am running OEM 350z springs/coupe springs on my sedan. So basically my car suspension is stock. Thanks for your input.
Old Jan 20, 2009 | 10:30 PM
G35fromPA's Avatar
You could also try the setting in between medium and hard on both F/R, BTW.
Old Jan 27, 2009 | 06:42 PM
jimmykce1's Avatar
Running medium on front/rear now. So far it seems a lot better.
Old Jan 27, 2009 | 06:45 PM
infinus's Avatar
I ran med/med on my coupe and it was alright, now its on hard/hard and i like it a lot better
Old Jan 27, 2009 | 07:22 PM
Rodrigo's Avatar
im currently running medium all around and it drives great , on hard it was a bit much for regular use,
never tried the first setting yet
Old Jan 27, 2009 | 08:00 PM
infinus's Avatar
^ at first had was annoying but now I've gotten used to it
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
