Compression rod?? same as Strut rod??
Old Feb 10, 2009 | 05:26 AM
fast04G's Avatar
I have yet another set of broken bushings on my 2004 g35 coupe. The only suspension mod is the tein drop springs. Im not sure what this bushing is called, but it is located to the rear of the lower control arm and near the crossmember. I couldnt find anything called a compression rod in any parts catalogue. Its a round bushing..can only see the rubber from the bottom, encased in steel.
http://www.trademotion.com/partlocat...=9&catalogid=1
This is the best picture i could find..looks like #9 i believe. The car makes muffled thuds from the front over bad roads..and going up my driveway..the little inch lip on the driveway. This is making my car pull slightly to the left.
If anyone can help! Thanks!!!
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Nov 1, 2015 03:26 PM
Claudiu
Sep 26, 2015 01:04 PM
