compression rod symptoms?
Old Feb 10, 2009 | 10:12 PM
g35ctuner's Avatar
does this sound like the compression rod, i have a pull to the right, at higher speed on un-even roads the wheel shakes like crazy (but is smooth as glass on even roads at same speed) and i just changed my front tires and the inside tread was all choppy and worn out way more that the outer tread. i looked at the compression rods for both sides and it is slightly torn, but not seperated like the one in homeboys other thread. does this sound like the issue? like i said, new tires mounted and balanced on the front and same issue. i want to blame the struts but i only have 52k miles and just cant see that happening just yet. thanks!
Old Feb 10, 2009 | 10:26 PM
GLuXuRy's Avatar
if your old front tires were worn out on the inside ... maybe your toe is off .. try getting a allignment before you start replacing parts
Old Feb 13, 2009 | 12:58 AM
g35ctuner's Avatar
all they're going to say is, we can't gurantee the alignment because you need compression rods.... but yes, it could be the toe. i think ill do both!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
dcsbh1
Oct 1, 2015 03:15 PM
