After lowering I noticed...
Old Jan 29, 2009 | 12:41 AM
nchima's Avatar
After speeds of 65+ I get a lot of rattling, and it seems unstable, compared to OEM. I'm dropped on Tein S-Tech for 350z, and have tockico shocks; and a rear camber kit. I have 285/35/19's in the rear and had my fenders rolled. The rattle seems like it is coming from the rear. I had the alignment done, but I just don't know what the problem is...go figure.
If I went back to my old setup of 275's in the rear, would that cure anything? Someone let me know.
Thanks
Old Feb 4, 2009 | 11:57 AM
waijai's Avatar
i.love.gold
Changing to a more narrow tire most likely won't fix a rattle. And by rattle do you mean some sort of plastic or metal clanging together noise? My suggestion would be to inspect your rear camber arms.
Old Feb 4, 2009 | 12:56 PM
Corrosive's Avatar
Was your camber adjusted for your 275's or your 285's... That could be it.
Also are they both 35 series tires?
Just a few of my thoughts without thinking too hard
Old Feb 4, 2009 | 01:00 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
If everything was reinstalled properly, there should be no new rattles.
Was this a DIY or by a shop?
Old Feb 4, 2009 | 01:01 PM
INF G'd Up's Avatar
Ya check the camber kit maybe who aligned it didn't tighten the adjustable arm , and ya what did they adjust the camber for the 275 or 285 tires
Old Feb 4, 2009 | 01:08 PM
Kris79's Avatar
battle froggy
i would double chek the install
Old Feb 13, 2009 | 09:59 AM
aannddyy's Avatar
Something might be loose? Yea check the install..
Old Feb 13, 2009 | 10:18 AM
Texasscout's Avatar
When I first put on my Z springs, for about a month when going at high speeds (80+), it felt like the car was "hunting" all over the road. It was very scary. When the springs finally settled and I got the toe set in the front, it was fine. As for the rattle, look for something loose.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
