G35/350z Coilovers?
Old Feb 16, 2009 | 02:48 PM
Canadian's Avatar
Canada, eh?
G35/350z Coilovers?
Does anyone know the differences between a coilover set for a 350z or a G35? I know they bolt up the same, is it just the length of the spring that would be different? I know Z springs stock are shorter, so I'm assuming on all Z/G coilovers that would be the only difference. If that is the only difference, what will a Z coilover setup be like on a G? Just limit you on how low/high you can go?
Old Feb 16, 2009 | 03:58 PM
G35Asian's Avatar
Yeah, everything is exactly the same between the two except for spring rates sometimes when it comes to aftermarket coilovers. Most companies make the coilovers the same for both cars including the same spring rates.
Old Feb 16, 2009 | 04:00 PM
INF G'd Up's Avatar
ya most of the time the spring rates are higher on the z's but they are the same nothing in the length is different
Old Feb 16, 2009 | 04:03 PM
Canadian's Avatar
Canada, eh?
Thanks!
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
